PaulJ wrote: Sun Mar 01, 2020 11:41 pm @exxos , I'm not sure there was any confusion concerning your development IDE boards. They work great and have an additional feature where they provide the $e00000/$0000 decode signal. I'm not sure anyone expected more. As far as the driver 11.0 is concerned the glitter enhancement is ~5% on the Lightning card which is not detectable sitting there waiting for the test to complete. Just a novelty giving it a try. So I haven't seen anyone saying they expected more from the IDE card. Even if the IDE didn't function the card is an asset in that its a easy way to get a $e00000/$fc0000/$0000 decode signal. I was interested in obtaining your latest version because its foot print was changed to miss the case support on a mega. The two I have work great and are in constant use and provide all the functionality I require. :D :D :D :D
I'm with @PaulJ here too, the HDDRIVER Blitter on/off test results with XFRRATE were weird, but in reality the difference in use was imperceptible, so my feeling is that it is a non problem. It's also as much about the on board TOS 2.06/1.04 capability, so to have that and IDE is spot on.
TBH I'm the sort of person who will try stuff out to see what happens, but at the end of the day I always knew it was a beta dev board. Performance with or without Blitter help is more than good enough for what I want.
Mine both work great, and since I did the SIL upgrades on both Megas, I have no problems working with the floppy at the same time. Like Paul I'm after the smaller footprint boards, as I don't really want to chop the case support leg on either Mega.
Even if Trudie doesn't appear, having those smaller boards will be just right for what I need, and I'll certainly be ordering at least 2 when they arrive.
Keep up the good work, it all makes Atari life better :)
@rubber_jonnie thanks for the update. I think I shall stick with my slow ide and V10 then :D
Received these in the post today along with many other boards @exxos and I have been waiting for from China. This is @exxos' revision to reduce the size of the board down.
I'll start building one up and see how long it takes to build.
PaulJ
Post by PaulJ »
Icky wrote: Wed Mar 04, 2020 7:04 pm Received these in the post today along with many other boards @exxos and I have been waiting for from China. This is @exxos' revision to reduce the size of the board down.
Icky, assume it will take approximately the same time as the previous versions.. :) :) :) If I recall correctly @exxos said he was putting them in the store as a kit, assume the board and a ATF1504. Do you know if the the lead pitch on the IDE is for the 40 or 44 pin?
@PaulJ - Until I build and test one we won't know what may be needed to get it to work. I'll update on here as we get this puppy working.
That said @exxos did a brilliant job shrinking this down. Right hand sides of boards are aligned in the photo.
Oh wow , that Is a lot smaller than I thought...
PCB is slightly different, so you will need a firmware tweak, as I said earlier and in my blog, I am trying to get the code to work in a 1504...
Cool, when can I get two!
rubber_jonnie wrote: Wed Mar 04, 2020 9:26 pm Cool, when can I get two!
When you finish your H4 ;)
exxos wrote: Wed Mar 04, 2020 9:39 pm
Is this how we get @rubber_jonnie to finish his projects. Hold him to ransom on the next Atari kit he wants :)
I like your logic @exxos
PaulJ
Post by PaulJ »
@Icky, I think it only fair that @rubber_jonnie not be allowed to go shooting or beat up any his little gun-fun buddies until he finishes his H4. And definitely no new toys until it's running.
:smackbum:
@exxos , looks likes its going to get a great fit in a mega with the reduced size. Actual be able to put the lids on my mega's not that the machines are even aware they have lids. I'll signup up for 2. :) :) :)
:thanksyellow:
