exxos blog - random goings on
derkom wrote: 18 Feb 2020 09:13 Nod, saw that. Just noting that your stats as they currently are don't look particularly representative. :)
Looks like the detections haven't been updated since 2013 and that was to add in windoze 8 :roll:
Anyone know any other similar programs which are actually maintained ?
IngoQ
Post by IngoQ »
You could give Matomo a shot: https://matomo.org/
It is a full fledged Website Analysis tool, but can also work by just analyzing the access logs, without the need for tracking code.
Ingo :geek:
IngoQ
Post by IngoQ »
I would not expect it to be. Measuring errors aside, we are talking about people that do not only collect old computers, but are interested in new hardware for them. That is a really small niche of hardcore nerds, and by no means representable of regular humans :-D
So a larger portion of "exotic" OS choices doesn't sound that far off. I am exclusively using Linux for example :)
Ingo :geek:
The stats I looked at were certainly more weighted towards Windows, based on the data that Netmarketshare gathers on OS market share. Windows is up there at nearly 90%.
I'd kind of agree with @IngoQ in that you're getting a more niche set of users, so it probably wouldn't be anywhere near that, but given Microsofts propensity for pushing Win 10, given you can only detect up to 8, then you're missing some stats. Conversely, you may not be getting good Linux stats due to lack of detection.
I guess ultimately it depends on how important that knowledge is to you.
rubber_jonnie wrote: 18 Feb 2020 12:53 I guess ultimately it depends on how important that knowledge is to you.
well, not bothered really, was just trying to get real word stats of visitors OS's on my site.
IngoQ wrote: 18 Feb 2020 11:55 You could give Matomo a shot: https://matomo.org/
+1 for Matomo. Have used it in many scenarios and it gives a wealth of data.
Been distracted with the H4... But in the mix of it all, ive been trying to patch the IDE code to use a 1504 instead of a 1508.. Not having much luck.. I should have some flashy clock V3s to patch and test.. Also a few PeST cables to finish off.
There is also about 50 STE boosters needing the GALs fitted and tested. All that will take a while.. But I'm not messing about if the boosters start becoming a problem again. I also shouikd have the SRAM prototypes where only flashy clock can drive them currently. They will mash with the next SEC boosters, but because of the virus the PCBs are all held up :(
I've also been doing a lot for stock in my store this past week , so not had much time left for anything else.
Another one of my test machines has died.. Same thing as normal.. Works fine for months, goes on shelf for a couple weeks, comes off shelf and just won't boot up. Will be glad when I get my H4s all working so I don't have to keep spending so much time fault finding these old motherboards. Its mostly 5% developing new hardware, and 95% fixing motherboards. I think if they get slightly bashed or bent random solder joints or tracks break or something. One board was soldered that bad I had to resolder half the thing.
I also want to design a RAM adapter for the H4 at some point soon. One using ZIF sockets so I can test various DRAM chips.. Having separate motherboard for each DRAM type mixed in in with all the chaos has also become a nightmare lately. Its either trying to get chips to fit in turn pin sockets, which takes ages, or spring type sockets which break after a couple of chip changes.. Or the motherboard dies..
I think my H4s will be, one for testing chips out on.. One for testing addons and another form testing the FPGA stuff on. Then hopefully instead of 20 motherboards on my shelf, i can just have those 3 and gives me more shelf space to get more organised with parts for various projects.
Spunds like a plan with the H4s, it's for similar reasons I had 3 of them.
Need to talk to @Icky about the third one though, so I can get a few bits done on that before they get misplaced in the junk pile.
Can'ya tell what it is yet....
It needs a name, so for consistency, FlappyFlippyRam?
Users browsing this forum: apple [bot], ClaudeBot, DuckAssistBot, gpt [bot] and 19 guests
