Noob building a TF534
Lynxman
Re: Noob building a TF534
I found a faulty a1200 motherboard for sale. It's included with another A1200 that the seller is selling, so I asked if he would part with the broken motherboard separately. I can get a nice case with keyboard for a decent price on Ebay. 2MB Chipram will be such a blessing, and AGA is great too.
PaulJ_2.0
I have solved this issue, but I have not much idea as to why it happens.Lynxman wrote: 12 Feb 2020 04:43 The IDE to SD card adapter arrived yesterday. I cloned the harddisk image from the CF to an SDcard and it boots and is faster, and measures 2 MB/s when benchmarking, but for some reason a lot of games complain that kick34005.a500 isn't valid, even though it's the same as on the CF. I tried copying the a500 file over again in WinUAE but games requiring that rom still don't work. The problem does not occur when I try the CF again. Weird issue. Guess I have to run a fresh install on the SDcard to get it to work.
On the original CF, lha archive the dev/kickstarts directory and copy that over to the SD and unarchive. The kickstarts will then work properly.
This isn't the cause, my drives are always 0x1FE00Lynxman wrote: 13 Feb 2020 19:13 It was the same, but I figured out why it happens. The Max Transfer of the SD card partition was too high. I reduced it to 0x1fe00 and now the A500 kickstart works. :)
It probably worked for you as it is intermittent as to if it corrupts the files. If you archive them and copy them over, they work 100% of the time.
Lynxman
I didn't copy the files to a Windows environment when I cloned. I created a hardware image which I recreated on the new card. I also tried redownloading and unpacking the kickstart LHA, from the same source as I used for the CF, on the new card, which didn't fix it. I tried every 34,5 kick I could find. Changing the Max Transfer immediately fixed it.
8 Bit Dreams
- Moderator Team
All my cards has 1FE00 transfer rate
and who is using copy option nowadays? It takes too long..
Just using WinImage 9.0c, to create and restore 8GB drive images in 5 min...
- Admin sponsor
Agreed. Much simpler and quicker.8 Bit Dreams wrote: 16 Feb 2020 09:56 All my cards has 1FE00 transfer rate
I who is using copy option nowadays? It takes too long..
I’d really like to explore unionfs and xdftools sometime to create a docker type solution for amiga.
PaulJ_2.0
I use win32diskimager for making and restoring disk images, but I have to copy the files to the directories when making a new fresh install image.8 Bit Dreams wrote: 16 Feb 2020 09:56 Who is using copy option nowadays? It takes too long..
I dont rely on other peoples images, all of mine are created specifically for each machine, so I have a few for the 500/600/1200 for different kickroms versions.
The WHDLoad kickroms have been a pain for me in the past when transferring them to a new image until I archived them. Since then I've never had an issue. If I copy them unarchived, they have even worked initially and then stopped working. It's an oddity.
Lynxman
Does anyone else have Amiga Test Kit 1.5 hang when testing the Fast ram from Workbench? If I run it from floppy it doesn't hang, and if I rundiagrom that's fine too, but im Classic Workbench it hangs when I select Fast Ram. I can try the CF harddisk too just to see if there's a difference.
supaduper
Do you have the MMU running ? if yes then Amiga test Kit will hang as there is a conflict with the softwareLynxman wrote: 17 Feb 2020 05:57 Does anyone else have Amiga Test Kit 1.5 hang when testing the Fast ram from Workbench? If I run it from floppy it doesn't hang, and if I rundiagrom that's fine too, but im Classic Workbench it hangs when I select Fast Ram. I can try the CF harddisk too just to see if there's a difference.
Lynxman
Ok that explains it. I thought about that yesterday but didn't figure out how to turn off the MMU again after installing MMULib.
Lynxman
I found these randomly on Ebay. Wonder if they would work. Looks like they can be plugged directly onto the TF534. Not as useful on an A500 since it doesn't have an alternate drive for loading stuff:
https://www.ebay.com/itm/4GB-IDE-44-PIN ... SwGEJcawYL
Never mind. There are cheaper units:
https://www.ebay.com/itm/Apacer-2GB-IDE ... Swp~pdW7Mb
