Tf534 problem with IDE speed
kulamario
Welcome
I just finish my TF534 everything working fine except Card SD/CF
System see partitions and start from card but speed is to slow sysinfo show me only 40kb/s
Anybody can help me please
System what I use is classic wb with kickstart 3.1
dalek
Re: Tf534 problem with IDE speed
Known issue for a lot of people - try an SD2IDE adapter and SD Card on a short cable. If you need a long cable, use a short IDE cable an an SD extension cable.
Like these:
https://www.ebay.com.au/itm/44-Pin-Male ... SwEhVdbLih
and
https://www.ebay.com.au/itm/SD-to-SD-Ca ... -xVTtuaDzA
EDIT: and make sure to use 'mufastrom' command in your startup sequence from the mmulib package http://aminet.net/package/util/libs/MMULib.lha
Like these:
and
kulamario
I use only SD2IDE connect very short ribbon cable 44pin to tf534
Card is in SD2IDE
No use extension
Card is in SD2IDE
No use extension
- Admin sponsor
If this is happening then there is an issue with interrupts. Basically the TF536 injects interrupts for the IDE interface but if they arent getting through for whatever reason then you will see tape speeds.
What Amiga are you trying this on? If things are this bad then you probably have some kind of soldering issue.
kulamario
I have A500 rev6A
Now I connect straight to tf534 still no changes
- Admin sponsor
Ah sorry i thought this was 536.. is the INT2 lead wired up?
kulamario
no i no connect this
where is should be connect?
- Admin sponsor
kulamario
thx very much now i have 1.9mb/s
kulamario
yes i have fast drive but after connect this INT0 keyboard stop working
in Amiga Test Kit no even one button work
in WB Classic on WDHLoad i cant finish demo or game only reset working
can anybody give me some advice please
