TF Riser Revision 0 Arrives
TF CD32 Riser
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: TF Riser Revision 0 Arrives
Post by arkadiusz.makarenko »
8 Bit Dreams wrote: 31 Jan 2020 12:38 Seems i got it wrong, was under impression Amiga crashes if You go lower than 140Kbps...
I think other way round.
Stm32 SPI and I2S speed is tied up with arm clock.
The slowest which you can set up is fPCLK/256 (clock is 32 or 72 Mhz?)
It seems that Amiga doesn't handle this speeds at all.
Therefore there is need of doing custom communication. Simply by setting value on GPIO pin and wait (delay).
~ Stanislaw Lem
supaduper
Post by supaduper »
arkadiusz.makarenko wrote: 30 Jan 2020 23:25
terriblefire wrote: 30 Jan 2020 22:37
I may have a shakey TF330 rev 1 kicking about that you could have .
Could I borrow it, until I will build my own TF330?
If you need a TF330 then I can send you one to help with the dev of the Riser, so if you need it contact me
arkadiusz.makarenko
Moderator Team
Moderator Team
I have realised that I have enough spares to build TF328.
It should do the job for now.
~ Stanislaw Lem
supaduper
Post by supaduper »
arkadiusz.makarenko wrote: 31 Jan 2020 22:09 I have realised that I have enough spares to build TF328.
Well if you need anything component wise ,get in touch as I have parts for the TF330 and the TF328
arkadiusz.makarenko
Moderator Team
Moderator Team
@terriblefire
Do you have cpld firmware available somewhere?
~ Stanislaw Lem
arkadiusz.makarenko
Moderator Team
Moderator Team
supaduper wrote: 31 Jan 2020 22:12
Thank you.
~ Stanislaw Lem
arkadiusz.makarenko wrote: 31 Jan 2020 22:13 @terriblefire
The github repo will be out of date, the most up to date version is on my main PC. Unfortunately i"m in the Netherlands right now.
arkadiusz.makarenko
Moderator Team
Moderator Team
I managed to confirm basic elements of my build:
1. Video out - crisp!
2. I can connect to stm32
3. I can see cpld
I don't have 100k resistor yet. I had to miss it on order.
I had to trim video connector and battery holder to fit them on the board. This battery holder is massive and raised to the same height like connector. I might have bought wrong one.
~ Stanislaw Lem
arkadiusz.makarenko
Moderator Team
Moderator Team
I had issues with USB, before I realised that I ordered 22nF instead of 22pF capacitors for oscillator circuit, which is required for USB to work, as on internal default clock there is 16MHz only.
Now I can see that APPLICATION_START and APPLICATION_DISCONNECT are being generated on connecting/disconnecting devices but I always get HID_UNKNOWN.
There is still something not 100% right, but ... small steps in the right direction.
~ Stanislaw Lem
arkadiusz.makarenko
Moderator Team
Moderator Team
Damn.
I have killed either stm32 or st-link.
I cannot connect to it any more.
EDIT: No, I managed to connect under reset. I am a moron.
~ Stanislaw Lem
Return to “TF CD32 Riser”
