27C400 EPROM emulators (beta) issue D technical discussion
PaulJ_2.0
Post by PaulJ_2.0 »
Oh mine came!
Found it likes 9600 Baud as I cant get it to program higher.
It might be due to my stupidly long cable though.
Next up, working out how to bank switch.
cmorley
Re: For Sale: 27C400 EPROM emulators (beta) issue D
Post by cmorley »
PaulJ_2.0 wrote: 21 Jan 2020 13:39 Oh mine came!
It is USB so baud rate option doesn't have any effect... however it does cause some terminal programs to change the size of their output buffer. What terminal are you using? Dump it and install SmarTTY! 27C400 image should program in ~5.5s
PaulJ_2.0
Post by PaulJ_2.0 »
cmorley wrote: 21 Jan 2020 14:12 It is USB so baud rate option doesn't have any effect... however it does cause some terminal programs to change the size of their output buffer. What terminal are you using? Dump it and install SmarTTY! 27C400 image should program in ~5.5s
I am using SmarTTY and it refuses to program anything but garbage over 9600 baud so the baudrate does have some effect.
I do put it down to my 5m cable though, like I said.
PaulJ_2.0
Post by PaulJ_2.0 »
OK it seems not to like USB3 then, as I plugged into a USB2 and it programs at 115200
cmorley
Post by cmorley »
My Dell laptop is USB3 and I've been using that both direct and through a USB 3 hub. I've not got a 5m cable the one I've mostly been using is 75cm
PaulJ_2.0
Post by PaulJ_2.0 »
No matter, it works fine as it is.
I'm thinking of having a Raspberry Pi Zero W powered inside the case of A 500+ connected to it so I can squirt over various Kickroms without opening the case. It would be handy as I like to swap between 1.3 2.05 and 3.1.4 pretty regularly.
I could just run a script that asks which KS by number 1-3 and reboot.
cmorley
Post by cmorley »
PaulJ_2.0 wrote: 21 Jan 2020 16:40 No matter, it works fine as it is.
Could you try a different cable with the USB3 port please? It'd be useful to know if if is the cable or something specific to your USB port/hub...
PaulJ_2.0
Post by PaulJ_2.0 »
I will have to make one up tomorrow and have a check. I think maybe USB3 is a bit more delicate when it comes to degradation over distance than USB2. I have tried it on my laptop and main PC, both are ok on USB2 ports only.
Re: 27C400 EPROM emulators (beta) issue D technical discussion
How are people wiring these up. I dont want to electro boom any.
PaulJ_2.0
Post by PaulJ_2.0 »
Snip a USB cable and wire molex to:
Red = VCC
White = D-
Green = D+
Black = Ground
It's a standard everyone follows so if you snip a USB cable you will find those colours.
Users browsing this forum: ClaudeBot, don_apple, kodak80, pixelpusher and 6 guests
