exxos wrote: Fri Sep 21, 2018 9:40 pm
My video was done to try and prevent damages to the boards as a lot of people are not good at this stuff. Sure more qualified people could do different methods.. but as many found, including myself, using a solder vacuum can easily damage pads, its why I avoided it in my video. Cutting pins and doing things one at a time means people will not start levering the NVRAM with a screwdriver, breaking the motherboard, ripping vias out etc when the NVRAM doesn't come out freely. I've fixed many boards due to such damages.
No objection if you want do a video, but have to think about who are not good at soldering, and how they will likely damaged everything, every step of the way. That is why I did the video, and the methods I did.
When opening my Falcon, it turned out the Dallas chip doesn't use a package with pins that could easily be reached (and cut):
- Dallas.jpg (229.94 KiB) Viewed 8140 times
Any suggestion how to proceed here?
