Limited TF536 Run - Sort of Sales (All gone)
68030 + SDRAM + IDE
ICRY
Re: Limited TF536 Run - Sort of Sales (All gone)
Post by ICRY »
Hello all
I am just wondering which is the best cpld version go for atm.
Many thanks
ICRY wrote: 18 Jan 2020 14:02 Hello all
Many thanks
Use the one in the github resource for now..
OK i have an observation that might help...
Try different CF cards. I've noticed its more sulky about the CF cards than the TF330 or 534.
PaulJ_2.0
Post by PaulJ_2.0 »
terriblefire wrote: 18 Jan 2020 16:03 OK i have an observation that might help...
I only attach IDE once it has run from floppy successfully, it's not related to the IDE.
OK its been a "hole in my bucket" kinda a day.
First my A500 worked but then died. Then I got it going but the PSU died.
Ended up replacing the CPU socket on my A500+ (which was needing doing to be fair).
I'm sorry to report though that i cannot reproduce this at all on any of my Amiga's :(
adam
Post by adam »
terriblefire wrote: 18 Jan 2020 18:10 OK its been a "hole in my bucket" kinda a day.
This is so weird that i guess somebody with affected setup should send you their a500 mobo + TF536, including CPU.
PaulJ_2.0
Post by PaulJ_2.0 »
If it helps, when uncooled Diagrom hangs here:
CPU: 68030 FPU: NONE MMU: NOT CHECKED
Checking for fastmem
Pressing left mousebutton will cancel detection (if hanged)
Checking if a 24 Bit address cpu is used: NO
- Checking for A3000/A4000 Motherboardmemory
- Checking for CPU-Board Memory (most A3k/A4k)
- Checking for CPU-Board Memory (most A1200)
Cooled it gives:
- Fastmem found between: $40000000 - $43FFFFFF
- Checking for Memory in 24 Bit area (NON AUTOCONFIG)
- Checking for Memory in Ranger or Fakefast area
Yeah i cant make it not work here. :(
EDIT: For what its worth this is my current firmware.. removed the CDTV patches but added the boot rom.
tf536r1_main_top_FULL_PHASE_7.zip
PaulJ_2.0
Post by PaulJ_2.0 »
terriblefire wrote: 18 Jan 2020 21:53 Yeah i cant make it not work here. :(
Wonderful, that fixed it.
PaulJ_2.0 wrote: 18 Jan 2020 22:38
Huh?
@alenppc try it?
Return to “TF536”
