TT Boot Logo
alienkidmj12
Re: TT Boot Logo
really nice logo that, wouldnt mind it myself, i take it you need to flash a new rom ?
Re: TT Boot Logo
For reference in TOS2.06 UK image the offset for the logo is 3257E and ends at 32985
thorsten.otto
Re: TT Boot Logo
The offset is not quite right, and also depends on the language of the TOS. For TOS 3.06(us), the logo starts already at $35fe8.
The table below should give the absolute address for all (official) tos versions (subtract $e00000 to get the file offset):
Most patched TOS versions that are floating around (like CZ and PL) are based on the german version.
The routine that displays the logo is located at $e0074a in TOS 3.06, and $e00762 in TOS 2.06 (for all language versions).
As already mentioned above, the logo is 96x86 pixels, thus 1032 bytes of data.
306us: e35fe8
306de: e36018
306fr: e36036
306uk: e35fe8
306es: e36044
306it: e36026
306sv: e36036
306sf: e36044
306sg: e36044
206us: e3257e
206de: e325ae
206fr: e325cc
206uk: e3257e
206es: e325da
206it: e325bc
206sv: e325ae
206sf: e325da
206sg: e325da
Atarian Computing
Re: TT Boot Logo
Now that you mentioned patched TOS versions, it occurred to me that since this is the ThunderStorm patched 3.06 TOS version (for obvious reasons), the offset might not be the same. Also, mine was the US version which I then changed to UK keyboard layout. So yeah, probably best to disregard my offset figures.thorsten.otto wrote: 31 Dec 2019 04:16 The offset is not quite right, and also depends on the language of the TOS. For TOS 3.06(us), the logo starts already at $35fe8.
Most patched TOS versions that are floating around (like CZ and PL) are based on the german version.Code: Select all
306us: e35fe8 306de: e36018 306fr: e36036 306uk: e35fe8 306es: e36044 306it: e36026 306sv: e36036 306sf: e36044 306sg: e36044 206us: e3257e 206de: e325ae 206fr: e325cc 206uk: e3257e 206es: e325da 206it: e325bc 206sv: e325ae 206sf: e325da 206sg: e325da
Re: TT Boot Logo
Thanks @thorsten.otto this is helpful information
thorsten.otto
Re: TT Boot Logo
The thunderstorm is only a patched TOS, i doubt that they changed all the addresses (although it would theoretically be possible if they used my source to recompile it). But you should be able to check it by disassembling it, the routine looks likeAtarian Computing wrote: 31 Dec 2019 08:36 since this is the ThunderStorm patched 3.06 TOS version (for obvious reasons), the offset might not be the same.
[00e0074a] 207c 00e3 5fe8 movea.l #$00E35FE8,a0
[00e00750] 2278 044e movea.l ($0000044E).w,a1
[00e00754] 1038 044c move.b ($0000044C).w,d0
[00e00758] b03c 0002 cmp.b #$02,d0
[00e0075c] 6728 beq.s $00E00786
[00e0075e] b03c 0006 cmp.b #$06,d0
[00e00762] 6722 beq.s $00E00786
[00e00764] d2fc 0500 adda.w #$0500,a1
[00e00768] 303c 0055 move.w #$0055,d0
[00e0076c] 7205 moveq.l #5,d1
[00e0076e] 3418 move.w (a0)+,d2
[00e00770] 32c2 move.w d2,(a1)+
[00e00772] 32c2 move.w d2,(a1)+
[00e00774] 32c2 move.w d2,(a1)+
[00e00776] 32c2 move.w d2,(a1)+
[00e00778] 51c9 fff4 dbf d1,$00E0076E
[00e0077c] d2fc 0110 adda.w #$0110,a1
[00e00780] 51c8 ffea dbf d0,$00E0076C
[00e00784] 6018 bra.s $00E0079E
[00e00786] d2fc 0280 adda.w #$0280,a1
[00e0078a] 303c 0055 move.w #$0055,d0
[00e0078e] 720b moveq.l #11,d1
[00e00790] 12d8 move.b (a0)+,(a1)+
[00e00792] 51c9 fffc dbf d1,$00E00790
[00e00796] d2fc 0094 adda.w #$0094,a1
[00e0079a] 51c8 fff2 dbf d0,$00E0078E
[00e0079e] 7e27 moveq.l #39,d7
BTW there is an (quite old) program named TOSPATCH that is able to do such patches , if you know how to use it. The original archives can't handle all language versions, but german and us/uk should work.
alienkidmj12
Re: TT Boot Logo
Could a tool be written to do it ?
frank.lukas
Re: TT Boot Logo
TOS_ICON ... (don't know if it works on other TOS versions besides the German one)
