Agranlunds TF534 Build
TF534 - 68030 + More RAM Board (More compatible with amiga hardware)
agranlund
Re: Agranlunds TF534 Build
Post by agranlund »
Since the Netusbee with uIP tool is really finnicky and doesn't work with the TF534 I decided to give PARCP-USB a try instead. Happy to say it works perfectly! :)
https://joy.sophics.cz/parcp/parcpusb.html
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
Hi,
may i ask You to backport Your current firmware to TF520?
Wanna try to run it on ST....
Thanks ;)
Atarian Computing
Post by Atarian Computing »
agranlund wrote: 03 Nov 2019 16:29 I build EmuTOS with -m68030 -DSTATIC_ALT_RAM_ADDRESS=0x01000000
The biggest performance boost comes from letting it know about fastram at compile time, this allows it to put a large chunk of its internal variables there instead of in ST-RAM (the Vampire V2 + V4 optimized builds do the same thing)
Is this something that hasn't been done on the TT030, and is it something it could benefit from?
agranlund
Post by agranlund »
I was under the impression that card already works fine on the Atari?
Since it doesn't have Fastram nor IDE I don't think there is really anything to backport to it - those were mainly the changes I did for the TF534 on Atari (along with some fix to make it compatible with Blitter).
The TF530 however, should probably work the same as TF534 on Atari, but I don't have a 530 so I cannot say for sure.
You can get built firmware binaries for both the 534r2c and 530r3 in the /bin folder:
https://github.com/agranlund/tf534
frank.lukas
Post by frank.lukas »
I want buy a TF520 but someone told me it not work stable under Atari TOS 2.06. The Speeder must be run synchronous to the Atari ST system/busclock to work stable.
agranlund
Post by agranlund »
I have uploaded Maprom v1.4 to github: https://github.com/agranlund/tftools
- Added support for roms at 0xFC0000
- Mapping system vectors and supervisor stack to fastram
- Mapping some of tos internal variables to fastram (TOS 2.06 only)
This change makes TOS 2.06 quite a bit faster compared to previous version.
It also also adds support for KAOS TOS 1.04.
TOS 2.06 with NVDI and Maprom 1.4:
TOS 2.06 with Maprom 1.4:
KAOS TOS 1.04 with Maprom v1.4:
EmuTOS runs a tiny bit faster than with the previous version but not really enough to warrant making new gembench screenshots.
agranlund
Post by agranlund »
There we go!
Upping the clock to 50Mhz finally tipped it over the 1000% average compared to how the machine started life :D
There really aren't that many options for accelerating Ataris out there so I am super grateful that this card exists and is open source.
Nembench v2.1:
percentages are against Falcon030
Integer multiply (16bit) -> 1.921 Mips (~313%)
Integer divide (16bit) -> 1.135 Mips (~313%)
Linear (stalled) integer -> 24.975 Mips (~313%)
Interleaved (piped) integer -> 24.975 Mips (~313%)
16bit read (100% hit) -> 24.630 MByte/sec (~313%)
16bit write (100% hit) -> 14.492 MByte/sec (~240%)
32bit read (100% hit) -> 49.261 MByte/sec (~313%)
32bit write (100% hit) -> 28.901 MByte/sec (~433%)
Linear 32bit read (ST-Ram) -> 3.919 MByte/sec (~73%)
Linear 32bit write (ST-Ram) -> 3.921 MByte/sec (~60%)
Linear 32bit copy (ST-Ram) -> 1.964 MByte/sec (~60%)
Linear 32bit read (FastRAM) -> 30.131 MByte/sec (~566%)
Linear 32bit write (FastRAM) -> 27.976 MByte/sec (~433%)
Linear 32bit copy (FastRAM) -> 13.988 MByte/sec (~433%)
:bravo: You will kill GB6 if those numbers get much higher! :lol:
Cyprian
Post by Cyprian »
impressive
http://260ste.atari.org
Post by JezC »
How about this as the next challenge for the Mongrel?
:coffee: :ball: :-D
Return to “TF534 (OBSOLETE)”
