Found some time this weekend to do some work on the board. Did the smt components.
By the way. Has anyone solder on the 19pin d-sub connector? My foxconn connector I got from my donor board will not fit. The two earth/relieve holes is to far back on the board for the connector.
DoG's Hx Mongrel build attempt
DoG
Re: DoG's Hx Mongrel build attempt
How its looking, there may well be 2 types of connector, but its not been confirmed yet. The holes match up exactly as per my STFM, so it can only be different connectors.DoG wrote: 07 Dec 2019 18:40 By the way. Has anyone solder on the 19pin d-sub connector? My foxconn connector I got from my donor board will not fit. The two earth/relieve holes is to far back on the board for the connector.
DoG
I see. Mine is like the holes for both the 25pin connectors. In the middle of the pins so to speak. To bad I can't drill/move the holes in the board. Maybe doing oval holes on the next batch/board?exxos wrote: 07 Dec 2019 18:43 How its looking, there may well be 2 types of connector, but its not been confirmed yet. The holes match up exactly as per my STFM, so it can only be different connectors.
PaulJ
Just put mine on last night so I could use the DMA test board. The leads wanted to pull the connector to far back into the board.. I put the leads in the holes, forced the connector into the proper alignment and set the screws and then soldered. Alignment is fine now but the connector wanted to sit too far in. :) :) :)DoG wrote: 07 Dec 2019 18:40 Found some time this weekend to do some work on the board. Did the smt components.
DoG
Haven't tried to force anything, just dry fitting some components to see if the alignment was good and notice that. But the 19 pins is pretty long so maybe they can stretch to make it fit.PaulJ wrote: 07 Dec 2019 19:00 Just put mine on last night so I could use the DMA test board. The leads wanted to pull the connector to far back into the board.. I put the leads in the holes, forced the connector into the proper alignment and set the screws and then soldered. Alignment is fine now but the connector wanted to sit too far in. :) :) :)
DoG
Yup, it will fit actually when doing that. Thanks for the tip. But now I see that the two 25pin connectors don't have solder masks on the board for the two relieve holes. Hmm, or the 13pin connector for the monitor or midi in and out.
PaulJ
Really doesn't matter, their plated through holes, All you need is to fill the hole with solder with the pin inside. Its not like your going to drag solder the connections.DoG wrote: 07 Dec 2019 19:14 Yup, it will fit actually when doing that. Thanks for the tip. But now I see that the two 25pin connectors don't have solder masks on the board for the two relieve holes. Hmm, or the 13pin connector for the monitor or midi in and out.
It's odd because I remember the holes didnt align ,so I moved them to make them fit. so I must have 2 variants of connectors here as well somewhere which confuses things.DoG wrote: 07 Dec 2019 18:58 I see. Mine is like the holes for both the 25pin connectors. In the middle of the pins so to speak. To bad I can't drill/move the holes in the board. Maybe doing oval holes on the next batch/board?
Maybe if someone has one which doesn't fit ad not using it they can send it me to figure out.
PaulJ
@exxos the serial and parallel connectors I purchase from you fit perfectly. The 19 pin I reused from a donor board were off about an 1/8 of an inch.exxos wrote: 07 Dec 2019 20:25It's odd because I remember the holes didnt align ,so I moved them to make them fit. so I must have 2 variants of connectors here as well somewhere which confuses things.DoG wrote: 07 Dec 2019 18:58 I see. Mine is like the holes for both the 25pin connectors. In the middle of the pins so to speak. To bad I can't drill/move the holes in the board. Maybe doing oval holes on the next batch/board?
I did measure the points from the connectors I have in my store.. Thing is though, Icky sent me a blank STFM board, and I printed out the holes and checked it against that board as well.PaulJ wrote: 07 Dec 2019 20:53 @exxos the serial and parallel connectors I purchase from you fit perfectly. The 19 pin I reused from a donor board were off about an 1/8 of an inch.
What board did you use a a doner machine exactly ?
Users browsing this forum: ClaudeBot and 187 guests
