PaulJ's H4 Mongrel Build x 2
PaulJ
Re: PaulJ's H4 Mongrel Build x 2
Post by PaulJ »
exxos wrote: Tue Nov 26, 2019 5:18 pm
Good News.. Received a board this evening and other ordered parts..:) :) :)
Bad News.... Ordered 2 received 1 ...:( :( :(
PaulJ
Post by PaulJ »
TimNaber wrote: Tue Nov 26, 2019 4:53 pm Love the Unique retro-case you are using.
What else but an Atari 1040 box cut down. :mrgreen: :mrgreen: :mrgreen:
PaulJ
Post by PaulJ »
Have almost all the discrete components and surface mount stuff installed. Most likely will not put on the 16 mhz osc since it covers 99.5% of the pads. Missing the 75 ohm sm resisters. They were backordered. Shesh... usually check that everything is shipping. So I had to place another order to cover missing items. They should be here Wednesday so I expect to power up on Thursday baring any more missing components.
Nice progress @PaulJ.
PaulJ
Post by PaulJ »
Getting there.. mostly sockets and IC's left. Should finish Sunday except for memory sim socket, 33 ohm resisters, and 75 ohm smt resisters. :D :D :coffee:
Coming along nicely @PaulJ.
PaulJ
Post by PaulJ »
Pretty much finished up with the parts I have. Ran into one part I'm short, SN74LS07.. :mad: Is there something I can use until my 07 shows up wednesday? The 75 ohm SMT resisters show up Tuesday but I can run without them with the diagram. So were getting there.
You have to use the correct parts :)
PaulJ
Post by PaulJ »
exxos wrote: Mon Dec 02, 2019 2:55 pm You have to use the correct parts :)
Realize that but sometimes there are parts are close enough where you can substitute. Shesh I even ask Phil if there's something I could plug in backwards that would work. :twisted: Guess I'm just going to wait. :(
PaulJ
Post by PaulJ »
Well everything showed up today so I have finish building the board waiting for that pesky sn74ls07 which should show tomorrow. :cry: I do need to set all the jumpers since a lot of the pins were not installed when I set them initially. So planning to shoot the juice to it tomorrow and check for any of @PhilC magic smoke. :excited:
