Gotek write on floppy
JmmParis
Post by JmmParis »
Hi,
It seem's that Hxc allow write on st files (.st),
does it possible to write file with Flashfloppy and if it is how ?
Thank
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: Gotek write on floppy
Post by arkadiusz.makarenko »
FlashFloppy supports .st files.
~ Stanislaw Lem
JmmParis wrote: 27 Nov 2019 18:33 Hi,
Thank
Yes you can write files on a .ST file format disk whilst using flashfloppy.
JmmParis
Post by JmmParis »
The last time I tried DevPac, I could not register my test file (less than 2ko file).
I don't remember the error message, (disk full but I'm not sure)
Is there an option somewhere to allow write to floppy ?
I would use a pc emulator and make yourself a number of blank floppy disk images and try those.
Theres not a read write setting other than the rw options similar to what youd have in windows.
Yep, I have successfully created a blank .ST disk image with Hatari or STEEM SSE and then used a Gotek with FlashFloppy to read/write/format the image file.
tzok
Post by tzok »
You could force write protect, but by default, write is enabled. Only be aware that formatting to a higher capacity (more tracks/sectors) than original image size will corrupt the image file.
Users browsing this forum: ClaudeBot and 17 guests
