exxos blog - random goings on
TimNaber
Post by TimNaber »
Is there a cable that has the ends you need ON BOTH ENDS?
ST: TT030 10/32m; Falcon 030 14m(2); MSTe 4m; MST 4m(3); MST 4m AdSpeed; 1040STf 4m(4); ST 4m(2); MF 44 w/SCSI2SD(3); MF 30(3); MF30 w/Drem
8-Bit: 320XE w/Ultraspeed+/FIXXL; 320XE; 130XE w/Ultimate 1m; 600XL w/Ultimate 1m; 800XL w/Omnimon XL/Boss XL/Omniview XL; 800 w/Incognito; 800 48K; Black Box Enhanced(3); 1050 Super Archiver II; 1050 Happy(2); XF551 360K(2); XF551 720K; HD Tower 480m
TimNaber wrote: Tue Nov 26, 2019 4:11 pm Is there a cable that has the ends you need ON BOTH ENDS?
Don't think so. Even those cables are getting a bit hard to find these days :(
Been on the hunt for replacement cartridge connectors.. These came this morning.. 2mm.. not right angle.. they almost fit as well :roll: problem is the connector doesn't have much "edge room" so the cards don't fit because they are basically 1 or 2mm to wide :(
They do actually seem to fit though with a bit of a shove.. hmm...
Finally got some built up.. need to re-test them all make sure they all still work before they go into stock.
Doing some UK 102/104 DUALTOS ROMs :)
Some pesky PeST's finally heading into stock...
These arrived today :)
Also busy packing up the alt-ram board prototypes and remaining pest cables to be sent off and built :)
Those look familiar. Must remember to test mine, it's been fixed but since then I've been busy on the H4
ari.tao
Post by ari.tao »
exxos wrote: Sun Nov 17, 2019 1:28 am Thanks to Icky, we have a render on how this will look :)
So this board is no bigger than the 68K CPU. Also stackable without using much additional height. This board can be driven with any up coming items, mostly flashy-clock to start with. Then we will finally have some proper benchmarks in GB6 for alt-ram tests :)
Is there any more info about this?
Falcon, TT & some more
ari.tao wrote: Fri Dec 06, 2019 2:11 pm Is there any more info about this?
I just posted about it above.
