This is FF70 on my girlfriends PC..
Chrome 78
Internet exploder 11
New webstore URL (BETA TESTING)
Re: New webstore URL (BETA TESTING)
ari.tao
No, don´t have installed Chrome. I can check it with Explorer also, but probably it´s the same. I think it´s a scaling issue...
If I do it like Your girlfriend in the Capture.PNG did, then for me a magnifying glass woudn´t be enough, I´d need a microscope for reading the texts...
Falcon, TT & some more
What monitor are you using ? If you scale to 90% and text is to small to read, then suggests you are likely more using a tablet screen not a monitor ? Even so, on my tablet using chrome, the screen scales, but there is to much information on the store page to really be compatible with tablets, so I don't really recommend it. If I remember rightly, there was some odd issues with other android browsers, but I don't remember which ones as I dont use any others.ari.tao wrote: 20 Nov 2019 10:28 No, don´t have installed Chrome. I can check it with Explorer also, but probably it´s the same. I think it´s a scaling issue...
If I do it like Your girlfriend in the Capture.PNG did, then for me a magnifying glass wouldn't be enough, I´d need a microscope for reading the texts...
ari.tao
Monitor is the build in of my Laptop, a 17" ASUS. Don´t have any other PC (but a lot of Ataris).
Well, never mind, was just trying to help a little bit in improvement. Sorry if I failed.
derkom
Do you perhaps have the Windows UI scaling turned up? See screenshot ...
ari.tao
There is no such menue System/Display in my Windows_8.1;
scaling in FireFox is 100%, see above; I´d like to have it 125% or even higher, but then horiz. scrolling is inevitable: no automatic text reformatting if frame is too narrow...
derkom
This is what it looks like in 8.1 ...
Perhaps still not your problem, but worth looking into.
Looks like everything worked out basically :thumbup: There was a couple of formatting issues on our end, but I just fixed those.Cosmic Puppet wrote: 18 Nov 2019 22:58 Looks great... I'll definitely be buying this now I trust the source. Will be this week. :)
ari.tao
Well, @derkom , the magnifying in Win8 You pointed to is set to 150% (default). So, that´s really the reason: 150% of 1300 is a little more than 1920. As I suggested above already, 1280 instead of 1300 should fit nicely.
Seven other shops I know all can do 1920 without horiz. scrolling, some even can do so with less than 1920 by ´Fließtext´ (sorry, don´t know the english word for this).
I think, if exxos doesn´t want to adjust, we should end discussing scaling.
@exxos , I will test Your new shop by an order in near future.
Btw., will there be a new batch of boosters for STe again?
derkom
Sure, there certainly may be some tweaks that exxos could make to make the store work better with less horizontal real estate, that's obviously up to him. Just wanted to get to the bottom of why things were different for you, and that mystery is solved. :)
Users browsing this forum: ClaudeBot and 205 guests
