I saw one of Terrible Fire's Youtube videos where he was programming the TF530 CPLDs with a Rapberry Pi, and I was wondering what programming software is recommended, with using the Rapberry Pi solution?
I have read about people having problems using Xilinx software package, and fake rip-off Chinese programmers. I understand the principle of using the Pi, as an alternative programmer, but I know very little with regard to Windows OS programming software, so any basic advice or suggested links would be warmly welcome.
Thanks
Programming Software With Raspberry Pi
- Admin sponsor
Re: Programming Software With Raspberry Pi
xcsprog. It’s all detailed in the video and on the wiki.
The Chinese clones are brilliant If you read the instructions and use them once with ISE 10.1. About 200 quid cheaper than the official Xilinx programmers
supaduper
I also did a howto with an downloadable Ras Pi 8gb image which has xc3sprog already installed and also there are downloadable text files with the commands so you can just copy an paste them into a terminal and program easily, just look in this thread all the info is there:
https://www.exxosforum.co.uk/forum/viewt ... 8&start=10
arkadiusz.makarenko
- Moderator Team
In GitHub older boards WIKI you have detailed articles about using RPi to program cplds. Really easy to follow.
Eg.
https://github.com/terriblefire/tf328/w ... spberry-Pi
Eg.
~ Stanislaw Lem
~ Stanislaw Lem
PaulJ_2.0
I think there is an issue where in the newest build, the cable device is changed, so you need to change the sysfsgpio to something like sysfsgpio_creator.
I would scrap that and use the Superduper download/guide.
oggie
Not sure what you mean, but I just finished building a t530 this week and I used the latest build along with a raspberry pi and the instructions in the wiki were perfect.PaulJ_2.0 wrote: 30 Oct 2019 15:33 I think there is an issue where in the newest build, the cable device is changed, so you need to change the sysfsgpio to something like sysfsgpio_creator.
arkadiusz.makarenko
- Moderator Team
Recently xcsprog library changed cable names. So command line need to be a little bit changed. Instead of for example this:oggie wrote: 31 Oct 2019 00:58Not sure what you mean, but I just finished building a t530 this week and I used the latest build along with a raspberry pi and the instructions in the wiki were perfect.PaulJ_2.0 wrote: 30 Oct 2019 15:33 I think there is an issue where in the newest build, the cable device is changed, so you need to change the sysfsgpio to something like sysfsgpio_creator.
sudo xc3sprog -c sysfsgpio
You need this
sudo xc3sprog -c sysfsgpio_creator
~ Stanislaw Lem
~ Stanislaw Lem
