STFM case remake
The place to discuss & share your 3D models or printable parts!
Re: STFM case remake
rpineau wrote: 10 Dec 2017 22:18 Ok I understand your intention.
So I agree that the "best" way to get new original case is the injection mold.
As for "custom new case" using either 3D print, laser cut or CNC cut, this can still be useful for people with an existing STF/STE mother board with a lot of extension that can't be closed anymore.
As for a case for the mother board remake you're working on, an ATX (or mini ATX) format is indeed probably the best option, with a custom back panel.
No easy to figure out what is the most needed/wanted .
This all makes for a good and interesting talk :)
Nothing ever easy with this stuff ;) Think spray paint the old case is best option ;)
As for injection molding, if community can raise £40,000 then sure I can get proper cases made, maybe around £30-£50 per case. But based on 1,000 cases.. don't know of shipping costs, likely large container, plus I would need to rent a garage to store them all in. Would need 800 people to pledge £50 minimum..
Maeke
Post by Maeke »
rpineau wrote: 10 Dec 2017 21:41 @Maeke, yes the diy route is probably the cheapest one.
To cut 2 to 3mm acrylic you need a CO2 laser with about 40W of power.
Also as we're talking about thin sheet of wood or acrylic, a CNC can also be used to cut the parts, cheaper than a laser cuter and less dangerous (think about fire, laser reflecting to your eyes, ... )
Rodolphe
I've obviously took into consideration the eyes issue, using an enclosure is still possible with laser light protection sheet.
As for the fire, cheap chinese 3d printers too can take fire, mine is protected against it, at least as much as i could.
If i take too long to reply, sorry my cat is sleeping on my laps.
Maeke
Post by Maeke »
rpineau wrote: 10 Dec 2017 21:46
exxos wrote: 10 Dec 2017 21:34 A "kit" form case would be a much cheaper option yes, but I'm talking of total accurate clone of the case. If people wanted a kit type case, then they could do it themselves.
So you want to take a block of "plastic" and CNC it to the exact STFM/STE case specs ?
I'm not against it but I think the reason most of us want new case is because we can't fit everything we want in the current one :)
Also as the STF case (bottom and top) are not 100% flat, this would be fairly complicated to do with a CNC and would require multi-axis CNC to do a top/bottom case with its sides (and back panel) and then flip it over to do the other side.
It's all a matter of cost and laser/CNC cut acrylic/wood would give us the option to make new cases for STFM/STE/MSTE/TT to the dimension we want to add cards and what not in them.
So may be these are two different projects..
Rodolphe
If i want at least one new case, it's because my stf came with a smashed uppder case, and i'm not the only one having this issue.
rpineau
Post by rpineau »
@Maeke :
I see. I was thinking of DIY laser cutter like these :
https://www.thingiverse.com/thing:1780556
Cutting acrylic with this could be a problem as it's fully open and will refract the laser light.
But yes Chinese ones are cheap-ish and fully closed.
Rodolpje
Maeke
Post by Maeke »
rpineau wrote: 10 Dec 2017 23:02 @Maeke :
Rodolpje
That's not what i meant when i talked about chinese stuff.
This said, the diy you linked to, surrounded by an ikea lack enclosure with a longer table (abviously, not the small square one). wood sheets on all sides could do the job.
I looked into laser protective sheets meanwhile, the price defeat the cheap diy idea, but glasses could do.
Sadly i can't do one myself, not enough room in my appartment, and i'd preferre to protect my cat from the laser.
rpineau
Post by rpineau »
Same here. not enough space, cat ...
Maeke
Post by Maeke »
rpineau wrote: 11 Dec 2017 00:45 Same here. not enough space, cat ...
Well at least there is a fablab in my town, but with my health i don't know when i'll be able to go.
I've ordered a 3D printed case from ireland to see what the quality is like.
At least with 3D printing changes can be made easily to the case. Cost is still a lot, costing around £450 to prototype this :roll: Cost me around the same to get the 3D files created, so totaled £1,000 easily so far :(
I be surprised if it actually prints out at all without collapsing..
Maeke
Post by Maeke »
exxos wrote: 11 Dec 2017 15:04 I've ordered a 3D printed case from ireland to see what the quality is like.
Well they'll certainly need some supports.
Gunstick
Post by Gunstick »
if it's an FDM printer, then supports are indeed needed.
With a stereo lithography printer, probably no supports or only minimal.
A powder printer: well it's support all the way, so basically no supports :-)
In a year's time I may have access to such a powder printer.
Return to “3D MODELS”
