BOOKMARK THIS PAGE !
TF360 Status
renee.cousins
Re: TF360 Status
I know you're not one for feature-creep, but the 680x0 line has supported a level 2 cache since the 68030. Add a healthy 256KB cache with some wait states when having to hit SDRAM. Slower SDRAM access should allow higher clocks and cache should greatly improve performance over even fictional single-cycle SDRAM. You just need a tiny bit of extra logic and some really fast SRAM -- and today, that's not much of a problem. DigiKey has 256x36b SRAM that are 3ns and 200MHz for under $6.
- Admin sponsor
Re: TF360 Status
Erm. this doesnt make sense.renee.cousins wrote: 06 Sep 2019 04:36 I know you're not one for feature-creep, but the 680x0 line has supported a level 2 cache since the 68030. Add a healthy 256KB cache with some wait states when having to hit SDRAM. Slower SDRAM access should allow higher clocks and cache should greatly improve performance over even fictional single-cycle SDRAM. You just need a tiny bit of extra logic and some really fast SRAM -- and today, that's not much of a problem. DigiKey has 256x36b SRAM that are 3ns and 200MHz for under $6.
1. The SDRAM can be accessed in burst mode. The 060 can access a line at a time 3 + 1 + 1 + 1... ( and i rekon i could make it go faster).
2. The SDRAM can do 170Mhz and the CPU craps out at 110Mhz.
3. The 060 already has a buttload of cache.
It would make more sense to buffer 400Mhz DDR ram in a tiny fifo than your suggestion.
EDIT: I guess I’m utterly confused why the cpu speed is perceived to be limited by the SDRAM. It’s not.
alenppc
- Moderator Team
Re: TF360 Status
I built my 360 last night.
I bought a 1.5A voltage regulator with non matching pinout so I had to build this contraption to connect it. Even so, it gets super hot. Not sure if it should be cooled...
At first I couldn’t get it to boot since I was trying this EC CPU. I didn’t realize it wouldn’t work: Now I’ve fitted it with a full rev 1 and it’s working nicely at 50 MHz. I need to create an appropriate CF card setup with 060 software before I can do more experiments.
Time is tight now that wife has gone back to full
Time work and kids require lots of attention... but I’ll do what I can :)
8 Bit Dreams
- Moderator Team
Re: TF360 Status
EC versoins doesn't have MMU nor FPU, hence it will not work :!:
LC's should work
LC's should work
alenppc
- Moderator Team
Re: TF360 Status
EC works on the A3660.
8 Bit Dreams
- Moderator Team
Re: TF360 Status
yes, it does work on A3660, but not on TF360, cause Stephen implemented FPU disabling in CPLD
EC doesn't need patched ROMs to disable FPU on A4000
- Admin sponsor
Re: TF360 Status
Not very well and probably only with caches off. Without the MMU you cannot set the cachability of memory regions.
alenppc
- Moderator Team
Re: TF360 Status
Never had issues on that particular card and I run it for a while on the A4000, caches on and everything. I am NOT saying that we should leave this as an option for the 360 I just didn’t realize it would cause boot issues on it, that’s all.terriblefire wrote: 08 Sep 2019 14:58Not very well and probably only with caches off. Without the MMU you cannot set the cachability of memory regions.
8 Bit Dreams
- Moderator Team
Re: TF360 Status
Thats absolutely correct, most programs expect MMU (and FPU) as soon as 060 CPU is detectedterriblefire wrote: 08 Sep 2019 14:58Not very well and probably only with caches off. Without the MMU you cannot set the cachability of memory regions.
- Admin sponsor
Re: TF360 Status
I actually dont know why the EC woudnt start on DiagROM... maybe it was just unhappy at 50Mhz.alenppc wrote: 08 Sep 2019 15:03Never had issues on that particular card and I run it for a while on the A4000, caches on and everything. I am NOT saying that we should leave this as an option for the 360 I just didn’t realize it would cause boot issues on it, that’s all.terriblefire wrote: 08 Sep 2019 14:58
Users browsing this forum: CCBot and 8 guests
