Nova GPU Case
The place to discuss & share your 3D models or printable parts!
Re: Nova GPU Case
I need to learn how to do that hexagon fill
PaulJ
Re: Nova GPU Case
Post by PaulJ »
You keep this sh#t up Icky your going to force me to buy a 3d printer. :!: :!: :!:
Re: Nova GPU Case
PaulJ wrote: 25 Aug 2019 18:52 You keep this sh#t up Icky your going to force me to buy a 3d printer. :!: :!: :!:
Don't do it you will only have more projects to do. :) I made a replica part for a friends shower yesterday as he couldn't find a spare / replacement part anywhere.
Re: Nova GPU Case
PhilC wrote: 25 Aug 2019 18:26 I need to learn how to do that hexagon fill
I did it manually using the pattern command in Fusion. Then filled a few hexagons in to make it look different :)
Re: Nova GPU Case
Finished. Well almost :)
Made the mesh vents slightly wider so that it is more stable and doesn't break. Am just printing out the rear panel now (one in picture has the prototype rear panel). I see a few little tweaks and then I'll stick this up on Thingiverse also as I don't mind, I'll stick up some STEP files as well as the STL's so if anyone wants to mod this design they can feel free to do so.
You can also see the Lightning USB connector coming out of the VME port and will adapt the enclosure to take that in and have the USB connector facing out the back of the enclosure where the fan vent is as can be seen below (or not as its black plastic).
And the reason for doing this all in the first place is to place on its side so it fits under the monitor.
Re: Nova GPU Case
Looks really good Icky, may have to print it if my Nova will fit in it tol.
Kinda like my fake external floppy drive tho :lol:
Atarian Computing
Re: Nova GPU Case
Post by Atarian Computing »
Looks really nice! I like how it's much slimmer than my mod. :thumbup:
Re: Nova GPU Case
Atarian Computing wrote: 26 Aug 2019 17:42 Looks really nice! I like how it's much slimmer than my mod. :thumbup:
Thanks for the initial idea :)
Atarian Computing
Re: Nova GPU Case
Icky wrote: 26 Aug 2019 17:44
My pleasure. This is exactly what needs to happen. Build on, and improve on, each other's work.
Re: Nova GPU Case
Have finally published the STL files on Thingiverse
https://www.thingiverse.com/thing:3831820
However I will place the actual cad files on this thread later if anyone wants to remix it for their own requirements.
Return to “3D MODELS”
