The TF536 arrives
68030 + SDRAM + IDE
chue
Re: The TF536 arrives
Post by chue »
Perhaps some other component is dodgy, like the power supply or A500 itself?
I had issues with it initially... Alen uses the pinstrip upside down compared to how I normally solder them (now ... I used to solder them that way round and had connection issues)
EzdineG
Post by EzdineG »
terriblefire wrote: 08 Aug 2019 13:21 I had issues with it initially... Alen uses the pinstrip upside down compared to how I normally solder them (now ... I used to solder them that way round and had connection issues)
Can you post a pic of one of yours? I’m a little confused as to what you’re inferring.
This photo..
The top half of the strip is longer and thinner. I orient it so the fatter bottom pins make contact with the Amiga
richx
Post by richx »
Hello! I'm confused as well, on the picture the bottom pins are thinner (meant
for socket) and top pins are fatter (solder side)...
richx wrote: 11 Aug 2019 17:05 Hello! I'm confused as well, on the picture the bottom pins are thinner (meant
But it doesnt work if you do that in my experience. The fatter pins fit nicely in turned pin sockets.
I’m not arguing what the manufacturer intended.. I’m just saying it doesn’t work.
Worth trying next time I build a board as the small pins are often too loose.
Is it a one shot thing TF? Ie does not damage the socket when inserted?
It’s not going to damage a turned pin socket. It will damage a square pin socket. I usually put a turned pin strip on my relocators.
terriblefire wrote: 13 Aug 2019 11:20 It’s not going to damage a turned pin socket. It will damage a square pin socket. I usually put a turned pin strip on my relocators.
Will give it a try next time, thanks.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
I am gonna try soldering it the other way round next time. It just seemed logical to me that one would want longer pins on the bottom, but I guess I was wrong.
Return to “TF536”
