Trudie - The Next IDE Board
All the good stuff hardware and software wise for the Phoenix H5 series motherboards.
czietz
Re: Trudie - The Next IDE Board
Post by czietz »
In HDDRUTIL, right-click on the CF card in the "Available devices" window and select "Show details" from the menu. Does it show the correct capacity of your CF card?
czietz wrote: 05 Aug 2019 18:06 In HDDRUTIL, right-click on the CF card in the "Available devices" window and select "Show details" from the menu. Does it show the correct capacity of your CF card?
Oddly no ?
exxos wrote: 05 Aug 2019 17:36
PhilC wrote: 05 Aug 2019 17:05 And I know how you enjoy a puzzle. Looks like the card is possessed :evil: :twisted:
It must be using the "B-side" of the CF card.. that's my theory :lol:
Ah, yes, good tracks but not necessarily good enough to make the album..
Investigating a new thought..
On the ST I have 1234 folder.. and this is what I get on the PC :lol: Can't feking win :lol: :roll:
czietz
Post by czietz »
Seems something is still broken with the byte-swapping, then...
czietz wrote: 05 Aug 2019 21:02 Seems something is still broken with the byte-swapping, then...
Probably would help if I knew what I was doing to start with :)
I think what the problem is, is that the sector numbers are getting swapped as sometimes I get really crazy negative values in HD10 for drive side. Though I am only swapping the data register, not the sector registers or any others. I think this is why the ST partition ends up like half way on the drive as it thinks its sector zero but its got some other crazy value instead. As to why that's happening, no idea :(
So the only way the ST & PC can see the partition is if I partition on the ST with WRITE ONLY byte swapping.. But then the ST & PC then display a folder on the ST created as "12345678" as "21436587"... but then that doesn't make sense as if the PC is byteswapped then surely it should come out correct and not match the filenames on the ST ?!
So byteswapping makes the partition work, but swaps the filenames... if I don't byteswap, the ST side works as normal, and then the PC doesn't see the partition.. so can't win either way :roll:
Even more confused now..
So I byteswapped and created the partition.. then removed the byteswapping code, rebooted...
On the ST... I created a NEW1234 folder...
On the PC
The previous filename... and on the right the new filename created on the ST..
So now it works, WITHOUT byteswapping... :WTF:
So I looked in HD10 and now its enabled byteswapping by itself :WTF:
:dizzy:
Just a shot in the dark as I've not used CUPL yet but if it uses subroutines, is it possible you've missed a return or something?
Return to “PHOENIX ZONE”
