Flashy Clock - Yet another DEV board
All the good stuff hardware and software wise for the Phoenix H5 series motherboards.
Re: Flashy Clock - Yet another DEV board
exxos wrote: 26 Jul 2019 15:46 Try this one...
FC4a.zip
Yep, that breaks it too. Want a job in the Destruction team?
PhilC wrote: 26 Jul 2019 15:50 Yep, that breaks it too. Want a job in the Destruction team?
Does this firmware work and you done the mods ?
https://www.exxosforum.co.uk/forum/viewt ... =40#p24339
You are also erasing the chip before programming ?
Yes done the mods and yes erasing first. Will try again with the latest just in case.
STill didn't boot with either 68000 or 68010. Screen stays at 60hz.
PhilC wrote: 26 Jul 2019 16:05 STill didn't boot with either 68000 or 68010. Screen stays at 60hz.
You mean the FC3A-1 firmware doesn't boot ? If that's the case, something is wrong somewhere as myself and Icky are using that version just fine.
The FC3A-1 works fine, it's the two FC4 ones that don't.
PhilC wrote: 26 Jul 2019 16:32 The FC3A-1 works fine, it's the two FC4 ones that don't.
:shrug: I will try and put my board back on to test it, but won't be until Monday now.
No rush st all. It's you guys I'm here to help, not the other way round
When you are ready you are ready. For now, I will try and break it other ways, ie 68010, fitting IDE on top, Pak etc etc.
PhilC wrote: 26 Jul 2019 17:29 When you are ready you are ready. For now, I will try and break it other ways, ie 68010, fitting IDE on top, Pak etc etc.
Its a shame the 68010 doesn't run faster, not even 16MHz :(
Never had one until today. I can always try one of your c1 5 boosters on it?
Return to “PHOENIX ZONE”
