Trusted CPU Suppliers Or Ones To Avoid
go0se
Re: Trusted CPU Suppliers Or Ones To Avoid
Post by go0se »
8 Bit Dreams wrote: 27 Jun 2019 22:05 Yeah..just need to add that graphical glitches ive reported previously seems to be produced by CPU's im using.
Have about 20x 33Mhz chips that don't want to run @50Mhz or are partially working...
will need to go at lower speed on TF536 to be able to deliver stable cards.. :x
I have had similar results when running 33Mhz labelled CPUs at 50Mhz on the 330. It might be better to use those on a less demanding card.
Do the same CPUs run without issue on ~33Mhz clocked 530/534s? as I think I'm right in thinking that TF has stated, as with the 330 only 50Mhz will be supported on the 536?
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
go0se wrote: 03 Jul 2019 11:36 I have had similar results when running 33Mhz labelled CPUs at 50Mhz on the 330. It might be better to use those on a less demanding card.
Well, to be fair - i haven't tried other frequencies than 50Mhz till now, TF534 allows that, but TF330's not,
building three new TF534 cards, will try to put 40Mhz oscillator on it and see how these CPUs work..
xraynorm
Post by xraynorm »
Hi guys.
It was mentioned on one of the TF videos that John "Chucky" Hertell is selling 060 cpus.
Does he have an email address?
Message ChuckyGang user on this forum.
Users browsing this forum: Bing [Bot], ClaudeBot and 7 guests
