Please DONT report TF534 Issues here
- Admin sponsor
Re: Please report TF534 Issues here
Sounds like maybe the IDEWAIT or IDEINT resistors arent soldered correctly or have incorrect values. 2k is about right.
- Admin sponsor
Before you do anything boot with a simple WB installation. If you're seeing 800Kb/s thats about right with an EC. It could be a screwy software setup.
PaulJ_2.0
I think it might be the resistors, the WB install is fine and minimal and boots quickly on my 530.
Thanks for the quick reply.
PaulJ_2.0
Resistors check out ok. If it's nothing else obvious it might be the CF reader, I know Kludge had a problem with his.
PaulJ_2.0
Yes it was indeed the adapter. I used the one from me A600 and it booted in no time.
kludge
PaulJ_2.0 wrote: 30 Jun 2019 23:37 Resistors check out ok. If it's nothing else obvious it might be the CF reader, I know Kludge had a problem with his.
I plan to check what the difference is between the CF adapter that does work and the one that doesn't. I think there are more resistors on one of them, but we'll see. It probably won't be soon, however.PaulJ_2.0 wrote: 01 Jul 2019 11:33 Yes it was indeed the adapter. I used the one from me A600 and it booted in no time.
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
PaulJ_2.0
Yeah it's quite odd, as the one that didn't work on the 534 works fine in the 600.
I've never had one play up before, as they are really quite simple devices.
PaulJ_2.0
This might shed some light on what's occurring with these adaptors.
kludge
That’s very interesting. Just came here to post images of my adapters (before seeing the video), and mine are exactly the same. The one with the transistors does work in my A600, but not connected to the 534.PaulJ_2.0 wrote: 02 Jul 2019 12:40 This might shed some light on what's occurring with these adaptors.
The working one only has a resistor for the activity led on it.
My lack of focus:
My lack of focus:
PaulJ_2.0
That's exactly the same as what's happened to me.
I've put the one with transistors on in my 600 and it's perfectly fine, so I wont be removing them and testing it on the 534, but I'm pretty sure it would solve the problem.
At least now if anyone has the same issue it's an easy fix for them.
