Try this one... i cant even test these right now so go careful.
330 disable function bug
- Admin sponsor
Re: 330 disable function bug
supaduper
Hi Steve, that JED file will not program , comes up with file error when trying to program with x3sprog
alenppc
- Moderator Team
I was able to program this one... it seems to be working even without the hw fix. I'll leave it on for a while, let's see if it holds.
supaduper
Ok mine must have been a corrupt download. will try it again tomorrow
dalek
tf330_2019_05_25_alpha.zip disable now working here too.
Anecdotally I found out about this the hard way. Only just built my card last night and was trying to figure out why it wouldn't run. Turns out that 'Disable' on the silkscreen means you need a jumper _removed_ to disable the card - maybe it could be called 'Enable' on future cards? Also the direction of the jumpers on the silkscreens is counter intuitive to me - I initially had it across the wrong pins! I should have double checked the obv file.
For anyone else building these also remember that power header silkscreen is wrong too, at least on rev 3 :)
Super happy with my card now, thanks for all your work once again Stephen!
supaduper
So it was a bad download I managed to program the TF330 with the above jed and the CD drive does not boot at all with a CD rom in it, it just goes to the Cd32 splash screen...is this the same for you Allen ?
- Admin sponsor
Ok seems like mixed results.
dalek
Actually my bad - I didn't have the CD drive plugged in. Same results - no jumper no CD boot (and no devices in the early boot menu) - just sits at the splash screen.
go0se
Same results here as dalek and supaduper, splash screen and no CD action.
8 Bit Dreams
- Moderator Team
New FW doesn't work on client's setup unfortunately. Sorry for bad news.. :|
