Hi,
I am install dma chip from board without externall blitter to board with external blitter and all working fine :-)) wire for clock booster is koaxial 50ohm without termination. All test ok . Super...
STe booster v 1.5 36Mhz
Re: STe booster v 1.5 36Mhz
Great well done!
nemox
Neverending story.
Problem - 32 Mhz with tos 2.06 and blitter,
and this blitter warm up to about 25 Celsius - when I move with the window - screen is damage.
when i cooled the bliter with cool finger screen is OK.
On 8 mhz is all OK.
And strangely is: in Tos 1.62 it doesn't happen, only in Tos 2.06
i will istall peltier article and everything will be ok :-) is joke
any idea?
another blitter chip ?
thanks
On 8 mhz is all OK.
any idea?
thanks
Possible could be blitter is not happy.
Though all these problems is basically why I just stopped making booster for STE, because they are just never ending trouble on some machines.
nemox
Hi
resistor p100 has 2.2kohm, can i try replace resistor for 1.2k, or cut power line to blitter and add to series diode to low voltage, what do you thing about this
thanks
thanks
You could try it.
Nothing I ever tried or needed to do. So I really can't comment.nemox wrote: 15 May 2019 20:28 or cut power line to blitter and add to series diode to low voltage, what do you thing about this
nemox
Hi, gut news. I replace blitter and works. :D
DoG
Great work! I need to get started with mine to get it working. Just installed it when I bought it but never got a screen.
Another Atari, a STfm I was working on, also didn't show a screen. Turns out that I have some problem with a hdmi cable, OSSC, flatscreen or/and scartcable. Display sometimes. *sigh* So it seems that it wasn't the STe fault.
Is your running at 32MHz or 36MHz now?
nemox
I'am running on 32MHz, clock from motherboard.
Users browsing this forum: ClaudeBot and 190 guests
