Milesunder wrote: Fri Apr 19, 2019 11:10 am
Just watched your video about the TF360 and I am really looking forward to seeing this when it goes into production. You and the team have done a great job. Really like the idea of it being a cross platform card. Again would like to get one for my a4000.
I have a couple of questions about the board and I apologise if you might have answered these questions in the past with other cards.
1) is there a reason for the physical size of the board? Comparing the TF330 to a FMV card or even a SX32 these cards are a lot longer. I didn’t know if this was by design or because of the production process. I guess the form factor would have to change if you did a 1200 version?
Cost. Bigger board = £££. I dont make it a mm bigger than it needs to be.
2) Due to the limited expansion features of the CD32 is it possible if you could add a Battery backed real-time clock to the board? This question is obviously a follow on from Q1 as I don’t imagine there is enough space for a RTC on the current design.
This is something I think should live on the riser rather than repeat over and over on the accelerator cards. Its a one off thing.
3) Is there a possibility of getting an upgrade on the graphics either making a 31khz VGA output or HDMI output. Or even including RTG on the card.
I have no plans or inclination to do this sort of thing at the moment.
4) have you considered an FPGA solution for the CPU to possibly reduce size and cost? Also to perhaps do a ppc version to run OS4.1
No because it adds cost and complexity. An FPGA is relatively expensive and needs multiple power rails (usually) and they arent tolerant of 5V. Plus i kinda did my project to get away from the FPGAs.
Please don’t think for a moment I am suggesting a Vampire clone but I think that some of these enhancements a great card even better.
Lastly and I don’t know if this is even possible but perhaps designing a SoC solution to allow a modern browser to run a browser on the Amiga. Obviously there are some x86 cards like the golden gate out there for 386 and 486 but no one has made a modern version. With intel compute sticks being so tiny i wondered if this could be done.
Again please don’t think this is criticism or ungratefulness but genuine enthusiasm for the project and the work you do.
I dont plan to make cards any more complex than the ones i'm making. My goal is simple easy to build cards for all. Bells and whistles are not something i'm interested in. So no PPC, No x86, No RTG and probably no FPGA. Sorry.. i'm not the guy thats going to do that stuff.
Why? Because i think keeping it simple is the reason why I have produced what I have. Most projects that started and never came to much did so because they tried to do too much.
Simple, cheap, easy to build.
EDIT: also I struggle to support the simple stuff. Anything more complicated would make my life a misery.
