Latest TF534 is here
TF534 - 68030 + More RAM Board (More compatible with amiga hardware)
chue
Re: Latest TF534 is here
Post by chue »
theq wrote: Mon Mar 11, 2019 4:50 pm Here is my TF534 BOM from Digikey. Since I'm totally fresh to this, and not been able to watch all of TerribleFire's YouTube videos, I'm not 100% sure which oscillator to pick. Therefore there are 3 to choose from in this BOM. Pick the one you need. :)
If you do see anything that could have been chosen differently, please tell. There more we share the better. :ugeek:
There's a correction that needs to be done for this BOM. For "Index 4", the caps in the BOM are too small (0201). They should be 0603. Here's the Digikey part that I am going to order:
399-15351-1-ND
I have enough trouble soldering 1206 sized caps, much less 0201s. When I saw them I knew there was a mistake :)
theq
Post by theq »
Yeah, good find. I discovered this too. Was a noob metric/retard unit mistake. :roll:
0603 metric is 0201 imperial. And this was supposed to be 0603 imperial...
Sorry about this. :)
chue
Post by chue »
Has anyone soldered on the SPI flash chip yet?
I tried the one from theq's BOM and it seems a bit wide. I also searched Digikey using the part number from GitHub "SST26VF016B" and all I get are 16 MB parts, not 32 MB as per the parts list.
So at this point, I'm not really sure what the right part is.
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
this BOM is screwed up. Flash chip You need is SST26VF016B
just like mentioned in BOM on Github
https://github.com/terriblefire/tf534
DigiKey Nr: SST26VF016B-104I/SN-ND
chue
Post by chue »
Thanks, I will order that next time I need something from Digikey. The BOM was quite useful, just a couple of mistakes on there.
Attached is an updated BOM, which has fixes for the 0.1 uF caps and the SPI Flash
TF534 BOM.zip
(8.83 KiB) Downloaded 354 times
theq
Post by theq »
chue wrote: Sat Apr 20, 2019 5:05 pm Thanks, I will order that next time I need something from Digikey. The BOM was quite useful, just a couple of mistakes on there.
Great job for sharing the love! <3 :)
And yeah, the SPI was wrong. Shouldn't have added it in the first place since it wasn't supported at the time. But to be fair the original BOM mentioned a 32MB SPI Flash. It got updated/changed just after I posted my "screwed up" BOM. :P
Return to “TF534 (OBSOLETE)”
