WTH. I'm pulling BR low with a 220 ohm resistor, so it should be stronger than the pullup. But I had completely missed the VPA connection. What does VPA do?Maximilian wrote: 21 Mar 2019 23:20 Could this be the problem?
In the a600 the BR is tied to VPA and those are tied to a 1k resistor.
So if you pull down BR you are also pulling down VPA......not a problem during startup but maybe during normal running?
Also the 1k pullups are a lot stronger then the 470/4k7 ohm resistors on the A500.
Edit: It doesn't sound like a great idea to have VPA permanently asserted. So, right now the DIP64 VPA is being pulled low by the 220 ohm resistor on the PLCC BR line... That probably needs to change. Next: Break the connection between the DIP64 VPA and PLCC VPA and connect the DIP64 VPA to the DIP64 BR. Or am I being stupid here?
