SUGGESTIONS
SUGGESTIONS
Post here suggestions to include in the new STF.
Here are some common ones..
HDMI output
Well , there is no way to do this without a scan doubler which can already be purchased cheap. They are not great but its the only solution. If someone wants to design a new SHIFTER using FPGA to do the frame buffers, upscaling and HDMI output then sure I will consider adding it on a future design.
DRIVE AB SWAP
Yes this will be added in a future revision.
YM STEREO
Well, 3 channels. I have included (for now) 3 resistors on the current design which can be used to isolate and bypass the audio section. If someone wants to design some addon, then I will add a proper expansion header for the YM outputs.
IDE
For some reason everyone is obsessed with IDE. If someone wants to design a IDE addon card then it can go in one of the expansion sockets. Though IDE is somewhat outdated and slower than DMA. Myself and P.Putnik have been working on a super fast DMA drive. It was mentioned some time ago. Though we had write issues. Though with a new motherboard, I think a lot of unstable issues will be gone. So we will try again to implement this super fast drive.
I have also briefly been talking to Jookie about us working on a simple internal version of ultrasatan. Again, this is DMA stuff. Overall there are plans for internal storage, but unlikely to be IDE.
PC FLOPPY HEADER
Yes, the floppy cable uses a PC style connector which is already implemented.
STE JAG PORTS
I think these could be added in the future, but for now I have no plans to add these.
STE DMA AUDIO
Likely not. This is part of the STE's MMU logic and may not be so easy on the STF. Of course if someone wants to convert it all to work on the STF, then it could be added in future revisions. UPDATE: The Suska MMU seems to support DMA audio so at least some logic will be there..
STE SIMMS
No! The current revision makes use of old ST-RAM cards from the Falcon. either 1MB or 4MB cards.
LAN
If someone wants to design a LAN addon card, then it could be added to future revisions.
FASTER RS232
There is a mod already to speed up the ports, This may be added in future revisions.
FAST-RAM
Yes in time there will be 32Mhz Fast-Ram. Though its not high up on my to do list. If someone wants to design one as a addon card then people can use that solution until its added to the main board.
FLASH TOS
Yes, eventually will be added when I have time to work on that solution.
32MHz BOOSTER
Yes, on future revision the booster logic will be integrated and switchable back to stock 8MHz mode.
020/30 CPU
This will have to be done as a addon card. I do not plan on breaking compatibility with this motherboard. But if someone wants to design a 030 card then it will be a simply plug in option.
020 is good as does not break self-modifying-code (lack of data caches) so in that respect its better than 030 CPU. Of course 030 has more features, but most interest is data cache.. but in case of Falcon, it does pretty much nothing, actually can slow machine down! So data cache only useful for 32bit access I think, mostly ROM and fast-ram.. but no real need for fast-ram on new machine if supporting 14MB ST-RAM at 50MHz. So I think 020 is only CPU of interest. Of course new motherboard could ultimately have 68000 & 68020 on motherboard and be switchable.
040/060 CPU
People need to understand that firstly, each CPU upgrade may run faster, but also breaks compatibility. More to the point, the 040 & 060 do not support dynamic bus resizing. So you can't easily "drop in" these CPU's without a huge amount of support logic. To date not many have done this and its not been open source. So if someone wants these as addons, they will have to put in likely years of work to figure it all out.
USB
I have no plans to design or add this. Partly because likely nobody will write drivers for anything. If someone develops a addon card with USB and writes the drivers, then it could be added by default in future revisions. Though likely this will remain a addon card. Assuming someone wants to develop it.
HIGHER RESOLUTIONS
Without adding in a new GFX card this isn't going to be easy. While a gfx chip could easily be added to the 68000 bus, it will of course need fast-ram and 32MHz CPU to keep up. Main problem is someone would have to be willing to write drivers. Second problem is finding a graphics IC which is usable and still in production.. which is likely none. The only possible solution would be a custom FPGA graphics chip. Nothing I can do or have time. Would still need software which I don't have time or know much about either. So this is unlikely to happen.
ATX PSU HEADER
To power the ST with a ATX PSU. This could be added. Though only really useful for people wanting to fit into a PC case.
ATX FORM FACTOR
Well basically no. Simply because I am designing a replacement board for the original STFM case. It may be possible to design a ATX board when all other work & mods are done. Though this could easily be years away from completion. Designing boards takes huge amounts of time, which I don't have. It has been also suggested this might be a better direction to go in since there is a lack of ST cases, So using a PC case would work out a lot better. Though I can't do both revisions and likely will stick to STFM layout as I feel not using a STFM case is losing half the ST's charm.
1.44 FLOPPY BUILT IN
Yes, this will be added likely on revision 2. It only involves a simple GAL so easy to do since I already have a solution for that.
RTC
Yes the Falcon style RTC circuit will be added in future revisions.
DSP
Adding something like the Falcon's DSP circuit I want to add at some point. Probably be expansion card initally. Obviosly we need a better sound system on the ST design and the DSP is just first thought of doing that. It can crunch numbers quick, so can act as a co-cpu. We can play MP3,WAV,MOD on the DSP already on Falcon, so I think its a good thing to ultimately add.
FPU
Well, probably not. IO mapped FPU, what software will use it ? Sure if someone really wants to add it, then they can develop addon card with it.
PROJECT GOAL
VERSION 1
The current project is to replicate the STFM (well STF) into a smaller PCB area while doing some basic upgrades. See this topic. https://www.exxosforum.co.uk/forum/viewt ... ?f=19&t=23 . First version is copying the STFM schmatic, making some basic changes, then producing a prototype. NOTHING else will be added to this board. I need to make sure I copied the schmatic correctly and test the changes I made before looking into adding other things.
VERSION 2
Assuming version 1 works, Version 2 will see some more basic changes, but mostly see the addition of expansion ports. All upgrades will be developed as a addon card. Note that I am only 1 person, I can only do so many projects at once. So if people want upgrades, then people will have to design upgrades for it!
VERSION 3
Likely 5+ years down the line. Once all addon cards are verified to be stable and working correctly. I may consider a more integrated board which will include such upgrades on the main motherboard. This will free up expansion slots for future use.
spiny
Re: SUGGESTIONS
Post by spiny »
Integrated rtc would be a nice add-on too.
Re: SUGGESTIONS
spiny wrote: 22 Aug 2017 18:52 Integrated rtc would be a nice add-on too.
Yeah forgot about that.
Maeke
Re: SUGGESTIONS
Post by Maeke »
Exact, even for a gotek you need to pay a licence to install the HxC firmware.
If i take too long to reply, sorry my cat is sleeping on my laps.
Re: SUGGESTIONS
Maeke wrote: 22 Aug 2017 20:49 Exact, even for a gotek you need to pay a licence to install the HxC firmware.
Yeah. I'm happy with floppy drive for most things. Though same with any Atari, it is basically a addon if people want it. If they want it, they buy it, plug it in and away you go. If I added it as standard, its pushing the cost up and people who don't want that, or can't afford all in one go, then it would limit interest.
My goal is an open platform which anyone can develop addons and people can easily fit them.
arf
Re: SUGGESTIONS
Post by arf »
exxos wrote: 22 Aug 2017 18:24 IDE
I would not necessarily opt for IDE, but for storage options you can buy today. SCSI drives and SCSI-ACSI adapter’s aren’t. That’s why CF or SD would be really desired by me.
exxos wrote: 22 Aug 2017 18:24 PC FLOPPY HEADER
Excellent! Makes building / getting parts a lot easier.
exxos wrote: 22 Aug 2017 18:24 LAN
There are solutions that are based on a 68000 bus -> ISA adapter, then plugging in a Realtek 8039 ISA NIC. Drivers exist.
exxos wrote: 22 Aug 2017 18:24 FASTER RS232
Excellent! The mods from Harun Scheutzow for up to 115k2?
exxos wrote: 22 Aug 2017 18:24 USB
There are solutions and drivers. Gaga e.g. with Czietz and others created a TT bus based USB adapter card - alongside with working USB mass storage drivers. CD rom drives and USB thumb drives already work. Even with SingleTOS.
exxos wrote: 22 Aug 2017 18:24 HIGHER RESOLUTIONS
I’d go for “overclocking” like with the old 10/12 MHz board boost hack, or with Overscan, or the newer 16 MHz board boost hack. New GFX card would introduce driver problems and so on; but boosting the existing hardware would, software wise, be a lot easier, as the existing Overscan software (and also Warp9 + NVDI) can handle that.
exxos wrote: 22 Aug 2017 18:24 RTC
… with an external CR3032 battery? Please no integrated battery in the chip …
Against signature spam!
Re: SUGGESTIONS
arf wrote: 29 Oct 2017 11:01 I would not necessarily opt for IDE, but for storage options you can buy today. SCSI drives and SCSI-ACSI adapter’s aren’t. That’s why CF or SD would be really desired by me.
I have designed a IDE interface, but simply no time to build and debug it.
CF cards are extremely prone to noise, and just think they are really bad solution. I'm not saying I am against IDE, but DMA is a lot faster, and does not eat up CPU cycles like IDE would.
With solutions like ultra-Satan, there is no real need to reinvent yet another hard drive solution.
Ultimately if I did opt for a internal solution, I would make something like the ultra-Satan on a internal mountable PCB for my new motherboard. It is basically makes IDE and CF obsolete. And of course it is a tested and proven design, whereas a lot of their IDE interfaces floating around always seem to have issues in one respect or another. And I do not really want to spend even more time reinventing and de-bugging this stuff, when there is something more reliable and better out there anyway.
arf wrote: 29 Oct 2017 11:01 ....There are solutions and drivers. Gaga e.g. with Czietz and others created a TT bus based USB adapter card - alongside with working USB mass storage drivers. CD rom drives and USB thumb drives already work. Even with SingleTOS.
There are a lot of hardware solutions, as you state for various things, they all need redesigning to be used better on a new motherboard. Obviously if you mount up the amount of work for doing every single modification and reinventing if the new motherboard as a standard feature, it quickly mounts up to years of work.
If it like I say before if people want to develop a add-on card the various features and people have to do it themselves. If it proves to be working and reliable solution, it will be implemented as standard on future motherboard revisions.
arf wrote: 29 Oct 2017 11:01 I’d go for “overclocking” like with the old 10/12 MHz board boost hack, or with Overscan, or the newer 16 MHz board boost hack. New GFX card would introduce driver problems and so on; but boosting the existing hardware would, software wise, be a lot easier, as the existing Overscan software (and also Warp9 + NVDI) can handle that.
Overclocking the original hardware is of course going to remain the most compatible method. That old 12 MHz hack it is basically useless. We are already running the bus at 16 MHz, and we can double the bandwidth of the video by doing this. This opens a door up for new video chips and resolutions as already discussed elsewhere on the forum.
Of course ultimately we need a compatible faster MMU. Then we can have 32 MHz access to ram, which will then effectively quadruple the video bandwidth.
arf wrote: 29 Oct 2017 11:01 … with an external CR3032 battery? Please no integrated battery in the chip …
Of course, I already developed this solution for the Falcon, and would use it on the new motherboard design as well as a optional plug-in extra..
https://www.exxosforum.co.uk/atari/store2/#0089
arf
Re: SUGGESTIONS
Post by arf »
exxos wrote: 29 Oct 2017 11:50 With solutions like ultra-Satan, there is no real need to reinvent yet another hard drive solution.
There’s no point in re-inventing the wheel for sure, and as I wrote, I wouldn’t necessarily go for IDE, but for modern storage options that you can buy new. Like the SD cards you mentioned.
exxos wrote: 29 Oct 2017 11:50 There are a lot of hardware solutions, as you state for various things, they all need redesigning to be used better on a new motherboard. Obviously if you mount up the amount of work for doing every single modification and reinventing if the new motherboard as a standard feature, it quickly mounts up to years of work.
Just wanted to point to that existing solution, as for the drivers it means that these exist (= no reinventing …). Of course the hardware has to be done, still.
exxos wrote: 29 Oct 2017 11:50 Of course, I already developed this solution for the Falcon, and would use it on the new motherboard design as well as a optional plug-in extra..
Excellent!
Maeke
Re: SUGGESTIONS
Post by Maeke »
arf wrote: 29 Oct 2017 11:59
Ultrasatan uses sd cards.
Re: SUGGESTIONS
Maeke wrote: 29 Oct 2017 12:25
arf wrote: 29 Oct 2017 11:59 There’s no point in re-inventing the wheel for sure, and as I wrote, I wouldn’t necessarily go for IDE, but for modern storage options that you can buy new. Like the SD cards you mentioned.
Ultimately I would try and have a ultra-Satan board which plugs over the top of the DMA chip via a expansion header. If the add-on board was close enough to the rear of the case, a small slot could be made in the back of the case so the SD card is accessable externally.
Jookie is planning at some point to release the design for Cosmo, so this could be adapted for internal mounting. But of course this is probably going to be all a long way away as I have still yet to finish the motherboard design, which I just do not have time for at the moment :(
Users browsing this forum: ClaudeBot and 34 guests
