TF330 Akiko Rev 0 Issue (SOLVED)
68030 + SDRAM + IDE
Re: TF330 possible issue?
Maybe someone can measure the resistance between those pins on a working CD32.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
I can do it tonight, can someone tell me which pins those are?
supaduper
Post by supaduper »
17,18 on 020
Just measured them at 1k
Presumably the timer tests work for everyone else?
supaduper
Post by supaduper »
15 CIA consecutive tests and no problem here bud
CD32 Diagrom CIA tests.jpg (250.57 KiB) Viewed 4115 times
I’m not able to check right now but the CIAB on the A1200 is on a diffent section of the data bus to CIAA...
However feels odd that the TF328 boots and the TF330 does not.
Does it boot with IDE removed?
anton.gale
Post by anton.gale »
I do not have a TF328. The unit boots with no accelerator installed. I'm going to swap Akiko out, I can't see any external pins that are dedicated to the functions that are being tested.
I would borrow a TF328 first. Unless you’re happy swapping Akiko.
It’s possible some games would get away with no CIAB timer. Especially CD32 games
alenppc
Moderator Team
Moderator Team
Post by alenppc »
This is a very puzzling bug. I asked nils if he'd send me his CD32 for me to try some local debugging since I will be doing some recaps for him anyway. I can't reproduce any of these issues on my hardware.
I find it hard to believe an Akiko would just be defective, I have not seen C= chips fail this way (except for the standalone 8520 CIAs).
alenppc wrote: Fri Mar 08, 2019 3:23 pm This is a very puzzling bug. I asked nils if he'd send me his CD32 for me to try some local debugging since I will be doing some recaps for him anyway. I can't reproduce any of these issues on my hardware.
Agreed. But something is causing that CIA timer to fail even without the TF330 installed. I can make the TF330 break CIAB and check the behaviour is the same.
I suspect a short somewhere.
EDIT: I don’t think anton and nils have the same issue.
Return to “TF330”
