I am having problems with Mint 1.19 on my Mega ST4, here is a screen shot showing how far I get.
Russ
Problems with Mint
rcamp48
Problems with Mint
Re: Problems with Mint
Does mint even run on ST ? Thought it was for the falcon..
You may be better with Geneva I think it was ?
I don't know about the latest MiNT kernels but anything up to version 1.12 came in both 68000 (default) or 68030 (special version) binaries.
Latest kernels are in those flavours too. MINT000.PRG or MINT030.PRGstephen_usher wrote: 24 Feb 2019 17:49 I don't know about the latest MiNT kernels but anything up to version 1.12 came in both 68000 (default) or 68030 (special version) binaries.
I found even on MegaSTE with 4MB its not really enough grunt and ram to practically use MiNT.
Ah, it must have bloated a bit over time then, probably all the plug-in filesystem and MiNTnet code. I did a bit of the initial coding/porting of MiNTOS on my 520STM with 2.5MB RAM and 28MB Third Coast Technologies (ICD + Seagate) hard disk. That was before the MiNT kernel worked properly on the TT. Those were the days... :lol:
To the OP...
Try disabling the extensions such as MiNTnet and that sound driver. Just include the minimal set of extensions, in case it's running out of memory.
mikro
Yeah, it should run on the ST as well. As mentioned, try to strip it down, ideally to only MINT.PRG without any modules.
