REV H1 information and interest
The H1 is the current board which I am looking to get made later in the year if there is enough interest..
The H1 schematic is here https://www.exxosforum.co.uk/forum/viewt ... =73&t=1475
I will update this thread with more info, I may have forgot to add things....
CHANGES:
All the changes and fixes from the Alpha which generated the REV G design https://www.exxosforum.co.uk/forum/viewt ... =19&t=1230
DMA / 1772 BUFFER ISOLATOR https://www.exxosforum.co.uk/forum/viewt ... =73&t=1437
CPU EXPANSION HEADER https://www.exxosforum.co.uk/forum/viewt ... =73&t=1452
POWER CONNECTORS https://www.exxosforum.co.uk/forum/viewt ... =73&t=1440
MONO SWITCH (similar to UBE switch) https://www.exxosforum.co.uk/forum/viewt ... =73&t=1448
SMT CAPACITORS https://www.exxosforum.co.uk/forum/viewt ... =73&t=1443
RGB DRIVERS REPLACED WITH FALCON DAC https://www.exxosforum.co.uk/forum/viewt ... =73&t=1442 AND https://www.exxosforum.co.uk/forum/viewt ... 260#p14851
DMA HEADERS ADDED https://www.exxosforum.co.uk/forum/viewt ... =73&t=1447 AND https://www.exxosforum.co.uk/forum/viewt ... =19&t=1289
FMCII RTC ADDED https://www.exxosforum.co.uk/forum/viewt ... =73&t=1458
RESET CIRCUIT UPDATED https://www.exxosforum.co.uk/forum/viewt ... =73&t=1441 AND https://www.exxosforum.co.uk/forum/viewt ... =19&t=1234
LS INVERTERS REMOVED https://www.exxosforum.co.uk/forum/viewt ... =73&t=1438 ***
RW ADDED TO CARTRIDGE PORT https://www.exxosforum.co.uk/forum/viewt ... =19&t=1261
DE JUMPERED TO BREAK GLUE TO MMU CONNECTION
ADD 72 PIN SIMM SOCKET https://www.exxosforum.co.uk/forum/viewt ... =73&t=1453
***A lot of TTL logic was removed in favour for smaller tiny logic gates.
PLANNED / WIP:
AB SWITCH https://www.exxosforum.co.uk/forum/viewt ... =19&t=1267
IDE https://www.exxosforum.co.uk/forum/viewt ... f=73&t=371
TO DO:
Fix and add various holes into the MB.
Locate and figure out how to mount US internally - (idea abandoned to speed up development).
Still not fixed the reset switch lib.
PEOPLE INTERESTED IN SUPPORTING the REV H1 BUILD
PaulJ X2
kodak80 X4
Icky X2
denni505 X1
chlu600 X2
IngoQ X1
tin X2
Xyla X2
JezC X1
redhawk668 X1
exxos X2
Rubber_jonnie X1
PhilC X3
DoG X1
poobah X1
alienkidmj12 X1
wietze X1
btl (aka Beetle) X1
derkom X1
( Post below if anyone else is interested, might have missed some people already sorry!)
kodak80
Re: REV H1 information and interest
Post by kodak80 »
Please update me to x4 for the boards.
PaulJ
Post by PaulJ »
Exxos, what is the minimum number of boards to pull the trigger on this thing? Is it still 40 @ 20 boards? You did miss denni505 on the prior thread. If its still a 20 board minimum we could divid it up and be done with it. Since there's 4 parties listed that's 5 a piece worst case. I'm sure there's others will be interested... RubberJ's always there for a challenge.. not to mention a few others. :?: :?: :?:
Second question, you sent out the video dac cards... was that v2 or v3.. i didn't build it because the output was flawless but will if it will prove anything and move us on. Please advise. :) :) :)
I don't remember what versions I sent out... some did the V2 but there was patches, so I did the v3 which is the design I built into the rev H1.. So it needs testing really in case something is wrong.. Otherwise there might be no video output on the H1.
OK to overly simplify all this...
As for "MOQ" , there isn't one. As said with the alpha.. Price gets stupid under 10. So do people want to pay £100 a board, or less.. Quantity goes up and price goes down for everyone. So 10-20 is what I think is a more reasonable cost .
Though as more boards are done, postage goes up, and then import taxes goes go etc so there comes a point where more boards doesn't give further discounts. Its like 20% saving in PCB cost for more done, then 20% import taxes.
I will try and get some prices soon and see what the best value run is.
PaulJ
Post by PaulJ »
exxos wrote: Sun Feb 24, 2019 4:31 pm I don't remember what versions I sent out... some did the V2 but there was patches, so I did the v3 which is the design I built into the rev H1.. So it needs testing really in case something is wrong.. Otherwise there might be no video output on the H1.
Exxos, is there a post that talks to the changes between v2 and v3?
denni505
Post by denni505 »
Thanks for the link looks interesting only one board for me thanks
PaulJ wrote: Sun Feb 24, 2019 4:40 pm Exxos, is there a post that talks to the changes between v2 and v3?
https://www.exxosforum.co.uk/forum/viewt ... =50#p14107
https://www.exxosforum.co.uk/forum/viewt ... 250#p14781
chlu600
Post by chlu600 »
Hi,
I'll gladly support another run.
As last time I don't want the actual board.
Have I missed the price?
But I'll support two boards :-)
IngoQ
Post by IngoQ »
Although I am sure my wife will kill me, I am in this time for one board as well :-)
Ingo :geek:
tin
Post by tin »
I’ll chime in and support this run with two boards (waited to long the last time, doh). Also I’d take two component kits (in case there will be any).
Also: big thanks to all the people who helped to make/debug the remake board btw. :)
