kludge’s TF530 build
TF530 - 63030 + RAM Board
Re: kludge’s TF530 build
Mine was a welder in WWII.
kludge
Post by kludge »
terriblefire wrote: 09 Feb 2019 12:25 Mine was a welder in WWII.
We were supposedly “neutral” in WWII.
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
kludge
Post by kludge »
Time for a bath. I forgot to add R2 at this stage. Will I need R2 for programming the CPLDs?
My lack of focus:
redhawk668
Post by redhawk668 »
Both CPLD’s, the LM1117 voltage regulator and the 6 pin header should be enough for the programmer. It worked for me.
My collection: 1040 STE, TOS 2.06, 4 mb, CosmosEx - 520 STFM, TOS 1.04, 4 mb, Blitter, CosmosEx - 520 STFM, TOS 1.04, 4 mb - 1040 STF, TOS 1.04, 1 mb, Gotek - Amiga 1200 with Blizzard 1220/4 - Amiga 500 + ACA500 - Amiga 500 + TF530, 1 mb chipram hack.
Atari 8 bit: 800XLF, stock - 600XL, Ultimate 1 mb, Sophia RGB - 130XE, 320 kb, Sophia RGB
Sinclair stuff: 3x Spectrum 48KB, Clones: Harlequin, JS128, Nuvo128 and Issue3B replica.
Ultimate64, a few C64 breadbins and Pi1541 for storage.
kludge
Post by kludge »
redhawk668 wrote: 11 Feb 2019 21:32 Both CPLD’s, the LM1117 voltage regulator and the 6 pin header should be enough for the programmer. It worked for me.
Great! It’s drying right now, so I’ll start setting up for the programming tomorrow. Then we’ll see if the CPLDs are legit or not :)
My lack of focus:
kludge
Post by kludge »
No. JTAG. Chain. Found.
It might have been a good idea to buy a new CPLD instead of using the one with the crooked legs after all ;)
Tried resoldering some of the pins... Or rather sides. With a K-tip :dualthumbup: We'll see tomorrow how that panned out.
My lack of focus:
PaulJ
Post by PaulJ »
Good luck Kludge, what are you using to program the CPLD's with? Is it destined for an Amiga or an Atari?
kludge
Post by kludge »
PaulJ wrote: 12 Feb 2019 22:20 Good luck Kludge, what are you using to program the CPLD's with? Is it destined for an Amiga or an Atari?
Thanks! I’m using a Raspberry Pi 2 to program. The plan is to put the 530 in an Amiga. Fanboy and all that ;)
My lack of focus:
PaulJ
Post by PaulJ »
Have a 530 to destined for a mega but not building yet until I come up with a TOS 2.06 solution. Also planning on using a raspberry to program the CPLD's so I'll be following your progress. Good luck!
kludge
Post by kludge »
PaulJ wrote: 12 Feb 2019 23:01 Have a 530 to destined for a mega but not building yet until I come up with a TOS 2.06 solution. Also planning on using a raspberry to program the CPLD's so I'll be following your progress. Good luck!
...or my lack thereof. Worst case I’ll have to replace the CPLDs, and I won’t order new ones until I’m ready to pull the trigger on CPLDs and RAM for TF534 as well. :)
My lack of focus:
Return to “TF530”
