kludge’s TF530 build
redhawk668
Re: kludge’s TF530 build
My first TF530 build went up in smoke.... When first switching it on after soldering it shorted and a little fizz and smoke was all I got
Fortunately, my Amiga 500 was still in good order and I could salvage my 68030, the RAM chips. My second attempt got somewhat better, after lots of soldering, reflowing, removing bridges, etc. it worked stable at 25 Mhz with a 68882 FPU. I've done a third attempt to build a new TF530 running at 50 Mhz, I succeeded in that. It runs, but I can't get the FPU running, so some more debugging needed. Another thing are crashes in WHDLoad.
My collection: 1040 STE, TOS 2.06, 4 mb, CosmosEx - 520 STFM, TOS 1.04, 4 mb, Blitter, CosmosEx - 520 STFM, TOS 1.04, 4 mb - 1040 STF, TOS 1.04, 1 mb, Gotek - Amiga 1200 with Blizzard 1220/4 - Amiga 500 + ACA500 - Amiga 500 + TF530, 1 mb chipram hack.
Atari 8 bit: 800XLF, stock - 600XL, Ultimate 1 mb, Sophia RGB - 130XE, 320 kb, Sophia RGB
Sinclair stuff: 3x Spectrum 48KB, Clones: Harlequin, JS128, Nuvo128 and Issue3B replica.
Ultimate64, a few C64 breadbins and Pi1541 for storage.
Did you have a terrible fire?
I want to make really sure that I don’t have any bridges left on the CPLD’s and that all pins are making contact before I start soldering in the other components. One of the legs on the RAM CPLD looks like it touches the leg next to it, but my multimeter seems to disagree.
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
redhawk668
I released the magic smoke
- 8 Bit Dreams
- Moderator Team
The reason for crashing in WHDLoad may be Autovector issue. You need to disable this function in whdload.prefs
[/quote]
Are you using a microscope?
[/quote]
Yeah same type as yours.
The 520 build was easy, everything just lined up. :/
I suspect the CPLDs I'm using are clones and somehow slightly out of spec. (They were the cheapest ones I can find). Even the labels on them are inconsistent. Some are even missing the pin 1 dot while others have it.
[/quote]
That’s weird. Did you have another source for the 520 CPLD? Or is it a different type? I’m not that familiar with the 520, as I started following this project when the 530 was being developed.
Or does the CPLD come in another package as well? But I guess it would be quite a lot of difference between the pads and the legs in that case.
How much is differing?
My lack of focus:
My lack of focus:
- Admin sponsor
The 520 CPLD is a VQ44... my granny could solder that with a hot rusty nail... the 530 is VQ64.. much finer pitch.
For soldering... use a K tip. I keep banging on about this but I don’t need braid to get rid of bridges with a k tip. Just clean the iron and dab gently with good flux applied and the spread you get clears the bridge.
Nobody listens to me though
I’m not using braid, just lots of Amtech flux. Didn’t use a K-tip though, just a regular wide tip. Will use a K-tip next time.
My lack of focus:
My lack of focus:
My granny used to work as a welder (I think she was the first female welder at Volvo, BTW), so she might be able to handle it as well
My lack of focus:
My lack of focus:
