I agree too as you know what some Amigan`s are like Lolterriblefire wrote: 31 Jan 2019 07:44 I agree. Its not the biggest issue.. The biggest issue is the disable jumpers. I'd like to figure it out though.
x4 TF330 spoiler below
Thanks Steveterriblefire wrote: 31 Jan 2019 08:54 Ok.
I put one of those 8Gb cards (clean) into my TF330.. and the SDCard adapter you gave me before xmas. Both have the same issue. Soft reboot always hangs.
To be clear. I open "Shell" and type reboot. Thats how i reproduce the issue.
EDIT: I'm using a machine without a CD Drive attached.
terriblefire wrote: 31 Jan 2019 13:14 OK found the issue i think.... not good.
I need to trace where AVEC comes from on the CD32 motherboard ... it should just be a pass through to the 030 AVEC pin.. :(
For reasons beyond me the CD32 chipset is continuing to assert IPL lines after the interrupt acknowledge cycle has completed. I've tried a few things like delays to these cycles. Nada.
I'm also very very suspicious of the CD32 AVEC line. Its pulled low and never never goes high.
For me it's 100% of the time, weird.supaduper wrote: 31 Jan 2019 09:33 So can now 100 % can confirm even on a clean system the REBOOT will not work...But very infrequenty it may :)
Users browsing this forum: ClaudeBot, OAI-Search [Bot] and 6 guests
