TF330 Soft Reboot Issue (SOLVED)
68030 + SDRAM + IDE
Re: TF330 rev2 is here
I dont have a CD32 on the bench just now to test. CDTV and A2000 are being worked on.
I really wish that HRTMon could do a memory dump to hard disk. :(
OK i confirmed this with a TF330r1. The rev 2 doesnt have any changes from the last rev 1 with patch.
Couple of things to try...
1. LoadResident with no fastmem.
2. Burning a ROM with no CD32 specific stuff in. I have a suspicion that the CD Drive DMA is the root cause.
Alen was there a version where this didnt happen?
EDIT: All my CF cards are trashed right now from the TF534 issues.
alenppc
Moderator Team
Moderator Team
Re: TF330 LoadResident Issue
Post by alenppc »
No, this happens on all versions. Will try without fast ram to see if there are any changes.
possibilities...
1. Bad ram design... unlikely as systest would show up issues...
2. Interaction between hardware and ram.
3. wrong ram flags
4. Reset causes reinitialisation.. not likely unless the RESET CPU instruction is called.
So we work through the list slowly...
alenppc
Moderator Team
Moderator Team
Post by alenppc »
OK, so disabling fastram before using LoadResident (i.e. loading into chipram) makes no difference.
Also, another issue. If you enter the Early Startup Menu and click on "Boot with No Startup-Sequence" freezes the system.
Very interesting. So not the RAM... maybe a cache issue
For giggles try running with the CDIS and MMUDIS jumpers closed.
Does this work on the TF534?
supaduper
Post by supaduper »
terriblefire wrote: 29 Jan 2019 07:30 Very interesting. So not the RAM... maybe a cache issue
Just tried on the TF330 with Both CDIS AND MMUDIS Jumpered no difference still hangs with load resident
Just say before using Loadresident on a clean System the `REBOOT` command works perfect but after using Loadresident it just wont work, so is the software corrupting the OS ?, I have not tried any other software where there is a reboot during the Install to see if this repeats.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
terriblefire wrote: 29 Jan 2019 07:30 Does this work on the TF534?
No issues whatsoever on the 534.
And also fine on the 328? It’s a very odd issue if it happens with fastram missing.
I’m going to sort the disable jumpers later.
One jumper will disable the CPU, one will disable just fastram.
supaduper
Post by supaduper »
terriblefire wrote: 29 Jan 2019 14:25 And also fine on the 328? It’s a very odd issue if it happens with fastram missing.
LoadResident and REBOOT works fine with the TF328
Are we going down a Rabbit hole with this LoadResident thing as there were always problems in the past with some software and some 030/40/60 accelerators
Return to “TF330”
