PAK issues
Re: PAK issues
pakman wrote: 28 Jan 2019 18:26 SRAMs are needed for the Second Level Cache, since this is where the cached data is actually stored.
Basically you can run the PAK without SRAMs, but only with the cache disabled.. and thus with lower speed..
Ok, so I should acquire some of the SRam but until then disable the SLC?
pakman
Re: PAK issues
Post by pakman »
Please change to the following jumper settings:
J9: 1-2 (set CPUCLK to 32MHz)
J10: 1-2 (set FPUCLK to 32MHz)
J4: on (disable the second level cache)
Keep everything else as is.. and switch on!
pakman
Re: PAK issues
Post by pakman »
Forgottenmyname wrote: 28 Jan 2019 18:33 Ok, so I should acquire some of the SRam but until then disable the SLC?
The speed gain it's definitely worth!
Or the other way round: Sell your Tag-RAMs as well! I noticed there are people desperately looking for it..
Re: PAK issues
I will probably buy the SRam once I have the pak working.
I've set those jumper settings and get a 60hz grey screen, the same as you'd get if the Rom wasn't booting.
pakman
Re: PAK issues
Post by pakman »
Okay, next test:
- Assemble a 68000 on top of the PAK
- Remove J5 (disable the PAK, enable the 68000)
Switch on.
Re: PAK issues
And still the same surprisingly, no boot
pakman
Re: PAK issues
Post by pakman »
Next:
- Try 68000 only, without the PAK at all
Re: PAK issues
pakman wrote: 28 Jan 2019 19:23 Next:
The Mega boots to desktop ok
pakman
Re: PAK issues
Post by pakman »
One more test, if you don't mind:
- Remove GAL P3 from the PAK
- Set both J5 and J6 on
Switch on..
pakman
Re: PAK issues
Post by pakman »
With the PAK assembled into the MegaST, of cause..
Users browsing this forum: Amazon [bot], Baidu [Spider], ClaudeBot, MEX68KECB, sporniket, Steve and 4 guests
