16BIT ROM CART THOUGHTS
Locked
Atarian Computing
Re: 16BIT ROM CART THOUGHTS
Post by Atarian Computing »
exxos wrote: Thu Jan 24, 2019 5:00 pm
exxos wrote: Thu Jan 24, 2019 4:45 pm
I only have 2 64K banks left, and 2 versions of YAART will use up both of those.
Or are you meaning the actual PRG file as thats about 8K ?
Would be cool on a RAM disk with both programs. Though I am not sure about it needing to get to the desktop over simply booting right up from cartridge.. Though I guess it does beg the question that other smaller programs could be loaded into the RAM disk as well I guess ?
You can do pretty much anything. You can have several small programs on regular cart image and ramdisk. The advantage of ramdisk is that it's not read-only, and you can use accessories and other file types as well.
Atarian Computing wrote: Thu Jan 24, 2019 6:16 pm Ah, I didn't know you were using 64KB banks. But why use separate banks for the ram tests? Here's a 64KB cart image with both tests.
I have perfected several methods to be able to pretty much put anything on a cart. Only the size is a limit after packing. There's room on this image for more as well.
If I understand this correctly, your booting to desktop and installing a RAM disk and I assume copying the programs to the RAM Drive ? Which means more RAM is used and then not tested ? If the RAM is not stable or has issues, then its all better all running from ROM ?
I guess what I could do is rip apart one of the lower address lines and splitting a 64K block into 2x 32K blocks, then I could fit YAART in that way as its only about 8K per program.. Then it would leave a 64K block to run your RAM disk on.. but not sure what programs be useful for diagnostics and be small ?
Atarian Computing
exxos wrote: Thu Jan 24, 2019 6:39 pm
For the ramtest a ramdisk is obviously not viable, hence the image above being just a regular cart with the programs in it. But again, why not keep both yaarts in one image?
Atarian Computing
Here's what it looks like on the desktop.
rpineau
Post by rpineau »
I'll take a PCB, I can assemble it myself :)
Atarian Computing wrote: Thu Jan 24, 2019 6:45 pm Here's what it looks like on the desktop.
Right, so you mean YAART on a cartridge drive, not on the RAM drive then ? In which case, what are you running on the RAM drive ?
I was just trying to see if I could fit both YAART into a single 64K block, The range I have free is a 64K block at $60000 and $70000. So YAART could go at $60000, and $68000.. That would leave the $70000 block free for a "cartridge drive"
Or do as you say, have the 2 YAART programs on a cartridge drive which would probably be more effective on space..
Its a shame GB6 wasn't smaller, that would be a great tool to have copied onto a RAM drive. Wonder if that would work if it was all compressed and extracted onto a RAM drive ? Saying that, the extraction code would probably take up a fair bit of room as well...
Ah nop, even ZIP on BEST has GB6 at 53KB.. thats probably pushing it.. I don't think the ST packers which would do this would even compress that well ?
OK so STZIP built a TOS self extracting file in 58K... So the question is, could the RAM drive be created with just 6K left ?
I'm assuming a AUTO folder could be created on the RAM drive and the GB6.TOS archive could be run from there so it would auto extract... :shrug:
Or just copy the GB6.TOS to the RAM drive and maybe desktop.inf could auto run it to extract...
Atarian Computing
exxos wrote: Thu Jan 24, 2019 7:12 pm OK so STZIP built a TOS self extracting file in 58K... So the question is, could the RAM drive be created with just 6K left ?
Here's the latest GB6 in a cart image I managed to squeeze under 64KB. This is not a self-extracting file but uses other blackmagicfuckery to contain all files in one executable and therefore not needing a ramdisk. This is then further packed with upx.
GB6.zip
(51.8 KiB) Downloaded 197 times
Atarian Computing wrote: Thu Jan 24, 2019 7:41 pm Here's the latest GB6 in a cart image I managed to squeeze under 64KB.
:shock: :shock: :shock:
That is just way to cool!!!
How you manage that, and so quickly ?!
Well done both, very interesting thread
Locked
