I am going to give Exxos an exclusive on this one , if you want to know about my new 3D printed design for the Ultra Satan case for RetroFun Boards, I will post it here instead of Facebook. And Yes Exxos I have no problem designing 3D printed stuff for your projects too. Here is the Thinkiverse link:
https://www.thingiverse.com/thing:3374756
Design just finished, gonna print another one tomorrow morning, unless someone wants to print one tonight, and let me know how it turns out, I have to go to the local library to 3D print, but its all free. Russ
Exxos: I don't know if this is in the right area, there may be an area more suited for it.
UltraSatan Case for RetroFun Boards Second Draft
Re: UltraSatan Case for RetroFun Boards Second Draft
:bravo:
I've moved it into the 3D section.
Nice one.rcamp48 wrote: 22 Jan 2019 23:29 I am going to give Exxos an exclusive on this one , if you want to know about my new 3D printed design for the Ultra Satan case for RetroFun Boards, I will post it here instead of Facebook. And Yes Exxos I have no problem designing 3D printed stuff for your projects too. Here is the Thinkiverse link:
Might I suggest that for your next iteration you reduce the wall thickness on the sides slightly? It will reduce print time, and since it doesn't need to be load bearing, the thickness isn't so important. You might be able to reduce the height a bit too.
rcamp48
This is my fourth draft, with holes in the standoffs, different colors , etc
https://www.thingiverse.com/thing:3375565
Will be printing it this morning to see if it fits. Russ
