Oh, good news! This was a weird problem.
Feel free to ask if you have another strange problem, EmuTOS with debug traces can be very useful to debug things.
Actually still have same problemBlankVector wrote: Wed Jan 09, 2019 5:48 pmOh, good news! This was a weird problem.
Oh. So please start trying EMUTOSUK.PRG as I advised to see what happens.
OK will do that now and see what happens...BlankVector wrote: Wed Jan 09, 2019 9:22 pm Oh. So please start trying EMUTOSUK.PRG as I advised to see what happens.
I just get this after loading the PRG.. nothing else..exxos wrote: Wed Jan 09, 2019 9:31 pmOK will do that now and see what happens...BlankVector wrote: Wed Jan 09, 2019 9:22 pm Oh. So please start trying EMUTOSUK.PRG as I advised to see what happens.
Oh. That's very unexpected.
Nope, nothing, just white screen while loading PRG, then that error dump. What is at that address ?? Says undefined in the Atari memory map docs...BlankVector wrote: Wed Jan 09, 2019 10:14 pm Did you see the EmuTOS welcome screen before the crash?
Blank floppy with TOS104 loaded from ROM... Only emutos on the floppy nothing else at all.BlankVector wrote: Wed Jan 09, 2019 10:14 pm Note that some AUTO/ACC programs may not be compatible with EmuTOS. Be sure to press Control (just once) at the welcome screen to avoid loading any AUTO/ACC program, hence avoiding trouble.
I have just tested the very same setup with Hatari and it works fine.exxos wrote: Wed Jan 09, 2019 10:25 pm Blank floppy with TOS104 loaded from ROM... Only emutos on the floppy nothing else at all.
BlankVector wrote: Wed Jan 09, 2019 10:38 pm How can it fail for you??
Maybe CPU, RAM, or other hardware issue??
PS: About the strange address, I suspect a jump to a bogus address (wrong RAM, buffer overflow...), then execution of a bogus instruction.
Does this mean that your hardware doesn't trigger proper Bus Error when expected? That matters for EmuTOS, because it uses Bus Error much to detect optional hardware (Blitter, TT & Falcon hardware, etc.).exxos wrote: Wed Jan 09, 2019 10:47 pm The diagnostic cart tests all seem fine, other than first boot, keeps saying "I7 BUS ERROR NOT DETECTED"![]()
