My own first ST project.
Re: My own first ST project.
Thanks Icky and yes that would be a good idea.
If you could share the library for the connector too that would be great, as I'll pinch it if I may :D
Sounds awesome Icky :)
Atarian Computing
Post by Atarian Computing »
Diag cart is a rite of passage it seems. Here's mine: https://www.exxosforum.co.uk/forum/viewt ... 7074#p7074
Forgottenmyname wrote: 06 Jan 2019 12:14 Thanks Icky and yes that would be a good idea.
I can't claim credit for the connector as I found it on the web. Will find link and post also.
If I remember tomorrow I will post the one I am using. Think rodople did mine a while back.
Posted files in the new section for PCB designs Exxos created
https://www.exxosforum.co.uk/forum/viewt ... =74&t=1528
Icky wrote: 06 Jan 2019 15:54 Posted files in the new section for PCB designs Exxos created
Thank you :dualthumbup:
Got the proto board wired up and my OCD kicked in with all the untidy wires,
The board worked fine but I'm jumping straight to Eagle for the rest as it's so much easier to visualise what you are doing.
Could someone please verify something for me please.
I am using the eagle library for the cart port and just checking the actual pinout of the port.
Is it top from left to right 1 - 20
bottom from left to right 21 - 40.
I'm sure it is but I am number dyslexic which tends to cause me to double check everything.
Users browsing this forum: ClaudeBot, OAI-Search [Bot] and 5 guests
