BOOKMARK THIS PAGE !
Mega ST part number wanted.
PaulJ
Post by PaulJ »
Does anyone know where I can buy the 64 pin mega st expansion port plug or know its part number? I got the last one from best and they didn't know its part number or where they got it. Thanks... :?: :?: :?:
rpineau
Re: Mega ST part number wanted.
Post by rpineau »
It's a DIN 41612 Male type B, 2 rows, 64 position (2x32),2.54mm pitch
I think this one is the right one :
https://www.mouser.com/ProductDetail/Hi ... K7AgVJc%3d
Confirmed :
https://www.mouser.com/datasheet/2/185/ ... 939616.pdf
Page A20, Pin Header: 2-row Straight Type : PCN10-64P-254DSA(72)
Rodolphe
PaulJ
Post by PaulJ »
rpineau wrote: 02 Jan 2019 00:17 It's a DIN 41612 Male type B, 2 rows, 64 position (2x32),2.54mm pitch
Confirmed :
Rodolphe
Thanks Rodolphe, just what I needed.. :thanksyellow:
Users browsing this forum: Ahrefs [bot], CCBot and 26 guests
