So, all the windings of the transformer measure okay, allways between 1-4 Ohms, which sounds ok to me.
Both capacitors I meantioned, measure properly using my multimeter. I realise that doesn't mean they haven't been compromised at all but I guess I'll just take the chance.
Resistor exploded in my monitor
sandord
Re: Resistor exploded in my monitor
Normally the monitor would (or should) go into a protection mode when the LOPT and/or driver fails.. But that will be another section, normally something like a BU508 drives the LOPT close by on its own heatsink.sandord wrote: 23 Dec 2018 21:02 Yup, at least I hope it didn't happen because of some other problem (could this have been caused by a short in the LOPT for example?)
It's pretty common for switching transistors on the primary side of transformers to fail. They are switching like 400VDC very fast, very spiky high voltage & frequency switching, So they are under alot of abuse and get pretty hot operating which doesn't help.
As for the smaller caps, I would suggest you change the electrolytic ones as its possible they going bad could have contributed to the failure.
Looks like you got 2x 50V 22uF in series there, I would be tempted just to put in a single 10uF (or 22uF) 100V cap instead.
sandord
I better order two regulator replacements then (for both monitors), they aren't that expensive anyway.exxos wrote: 23 Dec 2018 21:54 Normally the monitor would (or should) go into a protection mode when the LOPT and/or driver fails.. But that will be another section, normally something like a BU508 drives the LOPT close by on its own heatsink.
The caps were brand new, I replaced all caps in the monitor a few months ago.exxos wrote: 23 Dec 2018 21:54 As for the smaller caps, I would suggest you change the electrolytic ones as its possible they going bad could have contributed to the failure.
By the way, is the heatsink really that small?exxos wrote: 23 Dec 2018 11:55 EDIT2:
Looking at the small heatsink, if you could bolt something on making it "larger" then it will increase the life of the IC if it can run "cooler".
sandord
I was thinking, maybe I could solder a fuse in the path between the rectifier and the blown resistors. That would prevent a handful of blown parts in a future regulator-breakdown event. But how would I calculate the right fuse value? I guess I really should start that electronics base course now.
If they are new, then would assume they still be good.sandord wrote: 23 Dec 2018 22:01 The caps were brand new, I replaced all caps in the monitor a few months ago.
It depends. I mean that could easily hit 80c over a long run time for example. IC's will generally run happy for years like that. I was really just suggesting something to increase its lifespan as you recapped it already, so obviously you are looking to keep the monitor running good for years to come. The hotter things run, the shorter their lifespan.
You can get fusible resistors . They don't blow on current exactly, they blown on temperature increase. So if you could find a 1ohm fusible 2watt resistor or something, that should work. Its basically what the SR98 PSU's do but with 10R.sandord wrote: 23 Dec 2018 22:10 I was thinking, maybe I could solder a fuse in the path between the rectifier and the blown resistors. That would prevent a handful of blown parts in a future regulator-breakdown event. But how would I calculate the right fuse value? I guess I really should start that electronics base course now.
sandord
Interesting. I'll investage that as I've found regular 2W+ resistors to be quite expensive at Mouser. Better spend that money on something fancy then :lol:exxos wrote: 23 Dec 2018 22:15You can get fusible resistors . They don't blow on current exactly, they blown on temperature increase. So if you could find a 1ohm fusible 2watt resistor or something, that should work. Its basically what the SR98 PSU's do but with 10R.sandord wrote: 23 Dec 2018 22:10 I was thinking, maybe I could solder a fuse in the path between the rectifier and the blown resistors. That would prevent a handful of blown parts in a future regulator-breakdown event. But how would I calculate the right fuse value? I guess I really should start that electronics base course now.
By the way, I just powered up the monitor and...... it works just fine again. Phew! :yay2:
Thanks so much for all the help, I REALLY appreciate that, learning so much and enjoying it!
Had a quick look, only saw this one..sandord wrote: 23 Dec 2018 22:35 Interesting. I'll investage that as I've found regular 2W+ resistors to be quite expensive at Mouser. Better spend that money on something fancy then
:lol:
https://www.mouser.co.uk/ProductDetail/ ... SJFw%3d%3d
Oddly only looks like the 1R can take 300V.. So you might have to link 2 in series to be sure...
:dualthumbup:sandord wrote: 23 Dec 2018 22:35 By the way, I just powered up the monitor and...... it works just fine again. Phew! :yay2:
sandord
I turned it on today and something seems to be quite wrong... (please turn up the sound!)
I think I'll check for arching tonight, when it's dark. But my senses say this doesn't sound like arching.
Kinda looks likes what happens when got "noisy presets" which control H&V sizes etc.sandord wrote: 24 Dec 2018 11:37 I turned it on today and something seems to be quite wrong...
