EXPANSION HEADERS REV H1
As mentioned before, the first expansion header will be the return of the DIP 68000 socket. The board can use either a PLCC CPU or DIP CPU.
The PLCC CPU will remain as the main CPU, simply because the 68000 DIP socket is intended as a expansion header, so can be used for a 030 or IDE interface etc.
I may add a special header with the intention of a IDE interface as the DIP 68000 socket is large.
I don't think there will be a whole lot of room left on the MB after all current mods are done. Main issue is space under the keyboard for expansion headers.
PaulJ
Re: EXPANSION HEADERS REV H1
Post by PaulJ »
exxos wrote: Fri Dec 14, 2018 11:06 am As mentioned before, the first expansion header will be the return of the DIP 68000 socket. The board can use either a PLCC CPU or DIP CPU.
I second this approach, I really have no use for a on board IDE interface. I'm pretty much commited to ultra satan and may even use one internally if the internal DMA connector is present. Having the 64 pin dip as a basis for different cpu boosters is a good idea. Plugging a boosters into an SMD socket in my mind is problematic and not something I'd do. I really hate doggy connections. I would consider taking a SMD booster and soldering it into an 64 pin dip adapter. :mrgreen:
A thought popped into my head just..
With the addition of a GAL next to the PLCC CPU, it would in effect become the "STE booster" design. Other than routing DTACK & CLK8 via the GAL (can be jumper linked to bypass anyway) the STE booster GAL chip should pretty much "drop in".
It would give the MB a speed boost for doing pretty much nothing work wise, and takes the pressure off me a bit to finish the SEC design.
PaulJ
Post by PaulJ »
exxos wrote: Fri Dec 14, 2018 3:12 pm A thought popped into my head just..
That sounds like a good idea to me. Since there are going to be quite a few changes and upgrades we should divide up the design and check for issues when your finished to see if we can head off any un-fu*kit boards especially in the connector area.. :) :)
IngoQ
Post by IngoQ »
I vaguely remember, that the MegaBus is basically the 68000 pin out with some (more or less) simple logic added. Although I am quite sure this has been discussed already, I thought I mention it ;)
Ingo :geek:
IngoQ wrote: Fri Dec 14, 2018 3:28 pm I vaguely remember, that the MegaBus is basically the 68000 pin out with some (more or less) simple logic added. Although I am quite sure this has been discussed already, I thought I mention it ;)
Yeah, the connector is way to big, it could be done as a normal pin header.. Can't remember off-hand what the differences was in the signals to the megabus adapter.
IngoQ
Post by IngoQ »
Ingo :geek:
