POWER CONNECTORS
POWER CONNECTORS
What format do people want these ? There is the PSU connector pinout, or the floppy header pinout... Assume just more floppy power pinouts is what people want ?
Re: POWER CONNECTORS
+1 for extra floppies please.
At least 3 floppy power connectors from my perspective. The hole pitch allows JST XH PCB 2.54mm sockets to be added instead of headers as well.
What are people actually using these power points for other than floppy ? Any upgrades should have their own power pins on expansion headers, or pickup power close to whatever is plugging in internally like ultrasatan.
PaulJ
Post by PaulJ »
exxos wrote: 12 Dec 2018 10:14 What are people actually using these power points for other than floppy ? Any upgrades should have their own power pins on expansion headers, or pickup power close to whatever is plugging in internally like ultrasatan.
Good morning exxos.. personally what you have is fine by me. There's no internal DMA port so beyond the Gotek I have no need for additional power. If you had added the additional power ports I just wasn't going to populate them. The way I see it is the boards should be done in a tic tok fashion. All the changes and improvements in the tic.. and just fixes for the tic in the toc release. Although I know a lot of people are envious of my Atari box case its not a long term solution so most likely I will transplant the chips and memory card since in the long term the box case isn't viable. Just spin the board with the fixes and spend the time on the mongol board with the new improvements and updates. Just my 2 cents.. or in your case maybe 2 pence :thumbup: :thumbup: :thumbup:
PaulJ
Post by PaulJ »
I wanted to take a minute to give you a thumbs up on the power supply design. I ran the mega 4 all day yesterday with bench 6 with the case on. After running all day you couldn't feel any hot spots on the case after 8 hrs of running. That was not true of the atari supply. Your supply really runs cool and it did clear up some screen artifacts that were there with the atari supply. :bravo: :bravo:
I will add more power ports, just no idea what will use them.
Someone could make a cable and bring the power to the outside as a socket (USB?) and then power an external device, such as an UltraSatan directly from the machine. One less wall wart.
stephen_usher wrote: 12 Dec 2018 14:47 Someone could make a cable and bring the power to the outside as a socket (USB?) and then power an external device, such as an UltraSatan directly from the machine. One less wall wart.
Wonder if we could squash in a DC jack on the rear somewhere... Hmmm....
PaulJ wrote: 12 Dec 2018 14:08 I wanted to take a minute to give you a thumbs up on the power supply design. I ran the mega 4 all day yesterday with bench 6 with the case on. After running all day you couldn't feel any hot spots on the case after 8 hrs of running. That was not true of the atari supply. Your supply really runs cool and it did clear up some screen artifacts that were there with the atari supply. :bravo: :bravo:
:thanksyellow: :bravo:
Assume you mean the red PSU ? Probably the transformer runs the hottest overall I think.
Users browsing this forum: ClaudeBot, Google [Bot] and 5 guests
