What EmuTOS download for my Atari 1040STE with 4MB
General Discussion, STOS.
xav2075
Post by xav2075 »
The main webpage https://emutos.sourceforge.io/download.html takes me to a download "emutos-512k-1.4.zip" that has ROM files which its readme.txt file says are only compatible with Atari TT, Falcon and emulators of those. From the webpage https://sourceforge.net/projects/emutos ... mutos/1.4/ which download should I choose that will have .rom files I can split into two hi and lo files. Which in turn I can write to 128KB AMD AM27C010 dip 32 eeproms.
Re: What EmuTOS download for my Atari 1040STE with 4MB
You want emutos-256k-1.4.zip
STE only supports 256K ROMs. Split into high and low bytes, that's your 128K (1Mbit eproms)
mjaap
Post by mjaap »
256 KB in the language of your choice. If you want a more customised experience, you can also use Thorsten Otto's (RIP) online tool to generate an EmuTOS image with specific features.
If you don't want to solder the jumpers to select 27C010 EPROM then use 27C1000 as they are the same setting as the original mask ROM.
Return to “SOFTWARE”
