I never thought about checking if Frontier had a CGA mode. Apparently it does!SteveBagley wrote: Fri Sep 11, 2026 2:25 pm The interesting question is how well the 286 would compare![]()
Hmm, that would be interesting to find out, but I do not have the time to make such a version...SteveBagley wrote: Fri Sep 11, 2026 2:25 pm Not when its running at 90% of the speed of the ST3D maths is CPU heavy, which the Amiga's chips don't really help with. The interesting question is how well the 286 would compare
I think it's also a hardware implementation issue as well as software. The Amiga Bridge boards and the Acorn PC emulators (RISC PC excepted) both feature dedicated RAM for the x86 chip and so it is able to run concurrently with the 68000/ARM CPU except when transferring data (the screen, more likely instructions to draw on the screen).Badwolf wrote: Fri Sep 11, 2026 3:04 pm The poor old Amiga's inherent slowness aside for a minute, one thing that was left on the cutting room floor in my video was a rambling background thread about how restrictive the software for this is in the ST ecosystem.
True, but Falcon Speed relinquishes the bus every 18ms or so anyway (albeit for a very small time). Presumably to service interrupts? I would have thought event checking for window actions would have been possible at that rate.SteveBagley wrote: Fri Sep 11, 2026 5:11 pm Conversely, with the (PC|AT|Falcon)Speeds the x86 and the 68000 both address the same (ST) RAM and so only one CPU can access RAM at any one time, this effectively makes multitasking both CPUs impossible -- at best, you could have the CPU's take turns to execute instructions and run both at half speed. It's effectively the same as your DFB1, or any of the Amiga accelerator boards -- once the x86 kicks in, the 68000 is just waiting.
Bah. Tried it. Needs a 386!SteveBagley wrote: Fri Sep 11, 2026 2:25 pm The interesting question is how well the 286 would compare![]()
