Amstrad CPC464 motherboard
Re: Amstrad CPC464 motherboard
Acsi wrote: Thu Sep 03, 2026 8:19 pm
Nice.
Are you going to put it in a case or will it be a bare board?
Thanks @rubber_jonnie
I am thinking of maybe just a base but am also thinking of trying to bend some acrylic sheet (I last bent some at school back in the early 1980s) as that will give me something to mount stuff on.
I'd be interested to see how you get on with that, I've not bent acrylic since school either, probably a similar timeframe to you.
Acsi
Post by Acsi »
So first attempt. Not bad but angled and a bit wonky.
Kept going with that bit after having a second attempt at it (an advantage of acyclic sheet is the you can reheat it and try again it seems). 2nd bend got to hot and blistered a bit.
New sheet went better although I found that pressing to hard can leave dents from what your pushing it against (my old workbench)
And although not finished and only connected with what I had to hand rather than what it needs
Acsi wrote: Mon Sep 07, 2026 2:55 am And although not finished and only connected with what I had to hand rather than what it needs
Not bad at all!
Acsi
Post by Acsi »
A more completed case, albeit with a couple of mistake holes :D
It's not perfect but it is a Hackenstrad after all. The gaps are intentional and where I have bent the sheet isn't necessarily straight (far from it) but I like it.
A power switch and tape input connections have been done but so far no luck in getting something to load, might need an amplifier to boost the signal maybe? I don't have any tapes and my tzxduino reloaded v1.4 with maxduino v1.51 firmware doesn't want to play a CDT file so have been trying with a windows machine and a Samsung tablet. closest I got was to get a filename recognised and otherwise just get read errors.
Have ordered a ULIfAC which may make the tape connection redundant anyway.
Return to “8 BIT CORNER”
