Video driver thoughts
Re: Video driver thoughts
Forgottenmyname wrote: 26 Nov 2018 22:26
exxos wrote: 26 Nov 2018 22:25
Do you know which is DIL and SIL though :)
I was going to ask that tomorrow.
Yep - I know which is which unfortunately :(
Finally desoldered the socket
Highlighted is STF side (header pins).
Thanks :2k2:
exxos wrote: 26 Nov 2018 22:31 Highlighted is STF side (header pins).
Thanks - Question is though which caps are which.
I can tell the C1 - 3 as they are big.
Don't know which is which in the kit. as I have 3 of one kind and 4 of the other
exxos wrote: 19 Nov 2018 22:13 The 3 caps in the white strip are the 3 which go around the IC as close to possible. The 4 caps on the clear strip, go on the outside pads of the IC, and the 4th is next to the shifter.
Hth :D
Forgottenmyname wrote: 26 Nov 2018 22:47
Hth :D
Doh - I really am tired. Have been driving all day and I thought soldering would be a good wind down.
Hth :D
Beat me to it!
Icky wrote: 26 Nov 2018 22:49 Doh - I really am tired. Have been driving all day and I thought soldering would be a good wind down.
Hot coco then bed for you me thinks ;)
exxos wrote: 26 Nov 2018 22:50
Call me Mr McShaky Hands.
Got the board soldered it needs a clean up from all the flux but the harder I tried to keep a steady hand the worse it got.
Notice the small cap nearest the big ones and its wonky but has connectivity - I gave up on presentation skills.
Now I'm going to get a hot coco Exxos.
Testing in the morning.
:bravo:
Presentation is optional on Alpha builds ;)
